The Concentric Capacitor - Key to the Kapanadze Device and similar FE Concepts?
Started by Zeitmaschine, December 16, 2016, 04:40:24 AM
Zeitmaschine
Happy new year, happy free energy! :)
I'd like to start the new year with a quote from All About Circuits:
»What happens at resonance is quite interesting. With capacitive and inductive reactances equal to each other, the total impedance increases to infinity, meaning that the tank circuit draws no current from the AC power source!«
So the tank circuit needs no power source in order to oscillate? No problem with that! It is exactly what we are looking for!
My High and Low Voltage Capacitors Tests
12.5V × 900mA = 11.25W
12.5V × 800mA = 10W
Question: Where are the 1.25 watts coming from when the set of capacitor is connected to the high voltage secondary? Why can't I get the same 1.25 watts when any capacitor is connected to a LOW voltage secondary? Hmmm ...
Vice versa: Why should the high voltage transformer with a non-connected open secondary consume 1.25 watts in addition, not needed when the set of capacitors is connected to the secondary? Hmmm ...
Advanced stuff (in German):
Kapazitiver Transformator
W. Wiedergut - Testatika
They are close, but not close enough. Below are the illustrations how I see this.
High voltage pulses created by something (can be rotating disks) are connected to an in reverse working Tesla coil. The secondary coil (former primary) consists of just one single winding made of sheet metal, surrounded by a grounded (Faraday) cage. This forms a three-plate capacitor. As we can see, the load is connected to an extremely low-ohm power source, namely the plus and minus single winding secondary coils, connected together via ground. The Tesla coil and the outer plate are forming a concentric capacitor with the output coil in the middle. The high voltage input to the Tesla coil (maybe up to 100,000 volts) creates a strong Aether rotary motion which induces a high current in the single winding coil between.
The basic component, that collects the energy from the Aether, is the concentric capacitor. The reverse Tesla coil does only assists that effect; remember, the Hendershot device does not need a Tesla coil. So the question is, could this also work with an ordinary step-down transformer?
Unfortunately, I can't test my theories right now, because I'm waiting for the delivery of components ordered from China (Tesla coils are rather expensive in Germany). :(
But at least, we keep it so simple, one would laugh. If we know the Testatika secret, we know the Kapanadze secret.
Dog-One
Good research going on here Zeitmaschine!
I think you're really close to breakthrough.
What we know is this:
If you can combine voltage with amperage in-phase, you have real power.
I think the concentric capacitor technique is the means to achieve this.
We have plenty of voltage from the source.  You have access to high current
with the single turn shielded coil.  So if we can combine these two things in
such a way where they do not cancel each other out, there's real power there
for the taking.
Splitting the positive source away from the negative source appears to me
to be the correct approach.  I see this in your drawing.  I also see pulsed
DC which is needed for any induction to occur.  For things to stay in-phase,
the positive and negative commutators must be perfectly matched to
make-n-break at identical times.  Each side is the sink for the other side;
the load is the spring in the middle and must be compressed equally from
each side at exactly the same time.
This is a device where it looks to me like symmetry is critical unlike most
devices where asymmetry is needed.  I'm guessing the source is where
all of the asymmetry is concentrated.
The last part of this that is critical IMHO for proper operation is the
frequency of the pulses and the capacitance between the single-turn
coil and the outer faraday cage.  This capacitor must allow the frequency
of pulses to get through it at the peak of its Q-factor, otherwise the
bulk of that energy will be lost.
Great detective work so far.  I'll keep checking in on your progress
and provide anymore ideas that come to mind.  This looks to me like
a real possibility for success with enough patience and attention to
detail.
shylo
Interesting stuff, My question is, can you pull voltage from one lead of the coil, while pulling current from the other lead of the coil?
I think you can , just by way of differential in potential.
If you charge two cap banks, off of generating coils, discharge one while the other is generating, then reverse.
artv
Meta
Dog-one
_____________________________
Now you've discovered the polarity-like behavior of symmetry and asymmetry.
Now try thinking in terms of resonance and its partner, dissonance being just as polarized as symmetry and asymmetry.
Example: The perfect resonance of space (Aether) is v2/c2 = Phi
v2 is the square of the velocity of space (Aether)
c2 is the square of the velocity of light
Phi is the Golden Ratio
If Phi is the perfect resonant condition, what is the mechanism that can cause the dissonant condition.
Resonance>Dissonance>Resonance>Dissonance>Resonance>Dissonance.....   can you say pumping the Aether.
Think.
aether22
Quote from: Zeitmaschine on December 16, 2016, 04:40:24 AM
A summarization of the latest findings and theories regarding Aether powered electric free energy devices....
Hi Zeitmachine!
I too noticed this correlation, and I have also gained the ability to feel aetheric energy, and I have worked out a fair bit of what is going on.
I have found that aetheric energy "particles" have positive and negative charges, and they are affected by centrifugal force, but the electric charge, and any suitable magnetic field can act centripetally to keep aetheric charges moving at a very very high velocity in a circle.
Thus the electric and the magnetic fields must both force these aetheric  charges in the same direction if both are used.
In addition a source of such "aetheric charges" is desirable, spark gaps and other ionization is a good source.
Also it is good if they have a narrow space to move through, and it is good if that space is optically transparent, so 2 concentric metal cylinders charged with a narrow gap in between would be a good setup with a charge between the cylinders ideally.
John
