GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Hello massive,
.   thank you for being interested in building this GEM-free energy mechanism for me + this whole world.
I cannot understand why others do not want to build this simple + easy to build free energy multiplier,,,
If not only to just shut me up,,, lol + show me that it does not work.
Although I cannot see how this simple logic cannot work,
the using varying sizes of pulleys to multiply your # of rotations
+ thereby, if you add AC generators to your mini-pulleys, you are multiplying your AC electricity.
Most everyone that I explain it to, say that it sounds like it should work + then they usually say something like,
"this seems so simple, but it can't work,,, else why hasn't someone thought of it long ago,,,"
Quote from: massive on January 27, 2017, 01:51:25 PM
if the small pulley is 1cm , thats 10mm , what is the diameter / the shaft size??
https://en.wikipedia.org/wiki/Circumference
the formula is right there^^
"PLEASE SOMEONE,,, JUST BUILD ONE OF THESE SUPER SIMPLE FREE ENERGY MECHANISMS"
you said some one has already built one ^^
what type of DC motor ?  does it have a commutator ?    if yes then thats a problem
I will do the calculations + have to get back to you
Although these measurements do not have to be exact.
You only need to have one large pulley on your DC drive motor,
And a very small pulley to attach your AC generators to
So that you can get a maximum multiplication of rotations of your mini-pulleys + AC generators
I used 100 cm + 1 cm to make it easy to show the math of how it multiplied your rotations
YES,,, I said that someone has already built one, actually he built 3 different versions of them, and he said that they all worked. (which I happen to be very thankful for)
The only problem is, that he was worried about the rumors, that speak of anybody that builds a working free energy machine, soon ending up dead or missing, and he also worries about his family. So he will not give me permission to give out his name.
Not sure what you mean, I was just talking about a DC motor. The only specific specs that I know of that needs to be followed is your AC + DC motors need to be the same voltage.
SkyWatcher123
Hi all, just picked up an 86" length v-belt today at auto parts store for $18.
Will be testing it this weekend sometime with leg power and also turning pedals by hand, to get a feel for how hard it is to turn when charging a 12 volt battery.
Then the next step, is to hook a motor to pedal sprocket.
I have a 24 volt 200 watt brushed motor, from an electric scooter that should work.
I fully agree that_prophet, sometimes beliefs can act as chains upon us, preventing us from trying new things or even simple things we believe can't work.
I would say the same thing to all naysayers, build it, instead of just sharing opinions or beliefs.
If you build it, they or he will come.  :o ;) :)
peace love light
that_prophet
.   This uses such simple technology, by using the long belt that comes off a large circumference pulley=(100 cm circumference) which is rotating only once, (+costing very little electricity) This is to be converted into many,(100) rotations of a small pulley=(1 cm circumference). Thereby, using simple pulley mechanics, you are seemingly defeating the laws of thermodynamics + multiplying your total # of rotations, (+ by adding AC generators) you are multiplying your amount of AC electricity. These AC generators run free of practically any torque, as torque is caused when you generate power, (P=IV) or power is generated by multiplying the current times the voltage.
.    So even though you are winding up massive voltage,(which gives you great potential to do work) you are multiplying this by only one spark of current. (practically zero current) and massive voltage, times practically zero current is equal to practically zero power,,, which takes practically zero torque. You only need to generate one spark of current, because that is all the current that you need to power your DC drive motor, to have this mechanism self powering. (of course you need to add a full wave bridge rectifier to convert your AC output into a DC input, that you need to drive your input drive motor)
.   And lets not forget that you can drastically multiply your AC electricity multiplication factor, by simply adding additional small pulleys to the belt with your initial AC generator attached. If you add 10 (1 cm)-small pulleys you can multiply you AC electricity generation by 1000=10X100.
Quote from: SkyWatcher123 on January 28, 2017, 02:32:04 AM
peace love light
Please remember, that it is all of the evil spirits,
that are whispering in your ear,, THIS CANT WORK
(Satan is "god of this world") II Cor 4:4
they all want our money going to the oil rich countries
that in one way or another, fund terrorist
that_prophet
Quote from: that_prophet on January 29, 2017, 05:07:22 AM
.   This uses such simple technology, by using the long belt that comes off a large circumference pulley=(100 cm circumference) which is rotating only once, (+costing very little electricity) This is to be converted into many,(100) rotations of a small pulley=(1 cm circumference). Thereby, using simple pulley mechanics, you are multiplying your total # of rotations, (+ by adding AC generators) you are multiplying your amount of AC electricity. These AC generators run free of practically any torque, as torque is caused when you generate power, (P=IV) or power is generated by multiplying the current times the voltage.
and all these evil spirits hate us humans, (fallen angels + their offspring)
I figure, this is because we are His greatest Creation
+ not these angels, (which were His top Creation)
they will no doubt enjoy seeing our deaths, the more the better
especially since I read that well over 90% of us humans, (I heard it was 98%) are headed for hell
where these evil spirits get to torture us for all eternity
we are all in this "life" thing for the long haul,,,
once you are even conceived, you are in this life think for all eternity
there is no end...................... (no way out), except if you ask Jesus into your heart
our only choice is where we spend eternity
with God,(our protector) in Heaven,
or elsewhere,(hell + then lake of fire) where nobody will protect you
Paul-R
Quote from: that_prophet on January 29, 2017, 07:16:21 AM
enjoying seeing our deaths, the more the better
especially since well over 90% are headed for hell
where these fallen angels get to torture us for all eternity
Please provide proof for these statements.
