Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
Take all my posts with a pinch of salt anyways have a good day.
The translucent nature of zpe is where it gets it's motion from.
the translucent waves hitting a stick will give movement.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
Quote from: lltfdaniel1 on October 16, 2017, 01:51:36 PM
Turn into motive force like a em drive because you convert the zpe energy into movement
Because of some evil person is blocking know how as to how to tap zpe.
zpe energy is a perpetual force all by it self what do you think?
The translucent nature of zpe is where it gets it's motion from.[/size]the translucent waves hitting a stick will give movement.Turn into motive force like a em drive because you convert the zpe energy into movement
Converting zpe into motion would be a big start and can be done, if done it will prove it is a perpetual force.
Or convert the translucent effect into motion and then you will have a better understanding as to why this is perpetual.
The perpetual effect is clear with the way the force looks, it is unblanaced and this is where motion comes from to no end.
The stick can convert this into motion and is the barrier of the translucent effect so get an angle of momentum between the unbalanced poles like north and south and there you go.
you can contain this force, so it doesn't go off to infinity.
so it spins off to infinity.
Since zpe exist between atoms(this is what i call a stick) you can convert it into our electric magnetic spectrum.
In actual fact this zpe force has broken all the laws bottlenecks etc don't apply here due to the nature of this force - that is what was found when it was converted into our electric spectrum.
When zpe force collided with the electron magnet spectrum it was concluded that it has an effect where it breaks the law.
Because the force existing in electric is different with its sigh this is hard to explain.
Use the translucent force of zpe and have it convert it into motion (where it hits the stick) with the em drive, this is how the impossible em drive works folks.
It has the same principle (em drive) as with my idea about the earth circuit and converting zpe waves into motion
http://www.popularmechanics.com/science/a24745/science-behind-em-drive/
I can see a working turbine using the zpe effect of my earth circuit just had to work out the itneraction of zpe energy thats all,and some thunder when using em drive.
using em drive it has to create a quantum wave of motion whilst converting zpe energy waves that will break the physics indeed and indeed fully work as well theoretically speaking.
https://resonance.is/nasas-emdrive-quantum-theory-pilot-waves/
Instead of weeks it now takes days to reach a destination using em drive and using my theoretical brain storming.
There is a build up of momentum in my earth circuit where excess power is ultimate is proven.
Any how there are critics to my idea, as well as saying you cannot get perpetual motion, some say why they couldn't think as i do, as well as love, but plenty of laughs.
Anyways if i wanted free power i would revert to my earth circuit and have the earth resonance to accelerate via partical accelerator antenna.
There is only 1 thing standing in the way to make this a reality the threshold because it draws in negative energy regarding the excess power and the circuit has to have something where it transitions from positive to negative energy and this negative energy is the colder effect as opposed to the heat we already get in a circuit.
If and when i found out how to overcome i will then in detail explain how you can also get the same effect and then live off grid.
Any ways have a good day. :-).
lltfdaniel1
Since the earth has its own particle accelerator i was wondering how to make use of the earths particle accelerator potential like in an ion to suck ever more energy from the earth or am i not correct or is this even possible to increase amplitude?
Why didn't any one else thought about the particle accelerator antenna that am on about to make this possible?
There is no such thing as a particle accelerator antenna even though it would be a valid technology?
What other method do they have to increase amplitude to suck in more ions like with my idea of the particle accelerator antenna, i mean using the ions already to capture more ions so a self powered ion method, where yo use the captured ions from earth to cause an effect to suck attract even more ions like a wave with an increasing longer wave length as it does that.
Well you can indeed but it is no match with my particle accelerator antenna and it won't achieve my excess power dream as well but you still would suck more ions out of the sky at the very least so you need a long wire of antenna to get the desired amount of power.
There must be a method as to manipulate the earths own particle accelerator built in with the earths circuity.
It is already clear the amplitude of my particle accelerator antenna increases the wave length to tap into ions.
I need my particle accelerator otherwise you get puny energy from the earth, and i don't want to use a ballon hah.
I don't like inferior methods and refuse to think with such components so i leave you to use the inferior components.
I do still think it is possible to use the earths own particle accelerator to speed up the pump effect so to speak https://www.extremetech.com/extreme/162397-earth-acts-as-a-giant-particle-accelerator-creating-the-dangerous-van-allen-radiation-belts .
I think people are reliefed that i couldn't destroy the earth with such a device (partical accelerator antenna) maybe a self oscillating method to tap the earths own method of acceleration(earths own particle accelerator) which is entirely different method.
https://pwg.gsfc.nasa.gov/istp/news/9812/radiationbelts.html
Now to go about with how to use the earths own particle accelerator.
I think i need to input energy to achieve the effect to use the earths own particle accelerator.
Yes has been worked out i have to use inputed energy to cause the effect, how about already captured ions?
Like an ion powered input device which is different to normal electric powered input to cause the earths particle accelerator to wake up(be used).
I think i need to tune into the earths rf to cause the earths own particle accelerator in conjunction with other things.
Like dialing home to the specific wave length so it self resonates.
It will be in harmony with the earths own particle accelerator and no bottlenecks either, like using the control panel like with zpe/vaccum but for the  earths own particle accelerator.
http://news.nationalgeographic.com/news/2010/04/100419-lightning-natural-particle-accelerators-lhc/
I think people think i am wacko because of concerns like this > https://science.nasa.gov/science-news/science-at-nasa/2008/10oct_lhc
So a natural ion pump particle accelerator powered by the earth done by the earth i can see the advantage and it beats the conventional method of tapping power from earth like weather balloons with a wire to tap the earths power)
It would pick up speed as it uses the earths own particle accelerator.
In the earth process is the key to tap and use the earths own particle accelerator and isn't impossible and can be fully be used to this effect/end.
With a normal static antenna it isn't charged by the particle accelerator effect unless other wise you would get an ever increasing amount of ions which doesn't seem to have been achieved yet other wise all of us would be using the earths power instead  of power stations.
Any one with a brain unlike me will succeed with all my ideas and i can see that easily.
I need to tune it into the process matching ions frequency with the earths particle accelerator frequency.
At the very best it would be an energy saver for whoever decided to have a crack at this and won't be true over unity, it is like a magnet induction motor giving cop 3 but isn't true over unity with that magnet induction motor regarding a standard antenna cable which isn't accelerated instead look at the heat pump that is a true energy extraction device and you can indeed get it to be self-extracting with power using the external method of overcoming lenz law because the heat pump already has defeated lenz law. it will be self perpetuate because it is breaking lenz law like the perpetual force lenz laws defeated this will work this is what i said about it being external like ways to work around lenz law as you can see it will work as a self powered external solar power plant and will have no end in sight theoretically where it gets hotter and hotter and limated by the extraction process as to how much power you get out via extraction if you use heat pump method of fully defeating lenz law it will suck in ever more energy (actually getting its energy from zpe/vaccum) otherwise you will hit a brick wall like i said about my earth circuit not working and the bubble of understanding either way you can tap the energy to extract it with lenz law out of the way with the switching effect
externally means getting energy put into your circuit other wise lenz law will not allow you to inject energy into your system.
The switching effect causes energy to come from the zpe/vaccum i know that.
You need an open circuit just like the heat pump and this momentum comes from the earth's forces where the driving force is of acceleration as i put it regarding my earth circuit and all of that.
That acceleration effect is present in the heat pump already the energy it extracts from the environment is linked with the earth it self and her(mother earth) forces.
This method of bypassing the law is like the same with zpe/vaccum energy it is a unlocking effect.
lltfdaniel1
They found an opposite polarity force which is where you get energy from the vaccum from, and the polarity force didn't dissapation when you have the perpetual effect of Zpe vaccum energy done via the vaccum energy replenish effect
Of cold electric getting colder not hot which is the difference in dissapation where it should lose its perpetual charge but doesn't regarding the self perpetuate heat pump.
And the dissipation effect is opposite because we get excess energy like with my earth circuit or a self perpetuate heat pump which fully defeats lens law.
And saying the acceleration effect shouldn't work but it does.
No need to worry about dissipation because the vaccum it self perpetually self sustains that so it works and does work and is the drive of where we get excess energy to power it self as well as a load same with my earth circuit and the self perpetuate heat pump.
Regarding excess energy i can see positive energy being added to the circuit which in effect is tapping the vaccum/zpe and vaccum/zpe energy is being drawn here and have said what created the universe is in this process it has the power to create this is the unbalanced nature of all of it.
If you can clearly see the potential of my ideas then yes it will work in that fashion.
Also it is a big ouch for nay Sayers of perpetual motion because of the self-perpetuate effect of the heat pump which has defeated lenz law fully, where you use the extracted heat from environment(which gives a cop over 1) to feed it at the source so there is a never ending heat coming in see what i mean so where is the potential coming from of push and pull as it accelerates to the threshold regarding this potential it will cross over the barrier(extraction speed) of 92% efficiency since the heat pump defeated lenz law you can now pass over 92 per cent and this translucent force is now used can you see this, there you go that perpetual force is now used it is a polar opposite switch is what it is regarding  the barrier/threshold.
This is why they say the acceleration effect is impossible but isn't because there is a translucent force present in that accelerator effect which is of the exact nature of zpe/vaccum it self.
Polar opposite is what zpe vaccum is when it passes the threshold of acceleration it will exceed in power.
lltfdaniel1
The impossible has now been achieved with heat pump methods.
A switch went down and is now getting energy from the perpetual vaccum/zpe from the polar opposite polarity.
Even though it is normal switch the effect will be there.
