Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
WhatIsIt
Quote from: itsu on June 09, 2019, 11:51:34 AM
Hi Carroll,
yes that claim that a neon sign transformer was already OU is another goof up of him that opened up the eyes of many.
Anyway, it don't look like i will get any answers on my questions, so i will await my gaussmeter to arrive
and do some tests with it to see if i can find some extra energy with it.
Itsu
Don believe that HF (till 200khz, above that it is constant) is efficient above COP = 1.
All we have to do is use it. Convert it to usable energy.
That is his claim!
Gaussmeter will maybe show points of magnetic flux density or magnetic induction in the CGS (metric) system which name is the gauss, of higher flux density energy.
Which can be true!
But, extracting useful energy method from that points is something which you have to discover, yet, if you find one!
So, long way ahead! If you have a will to share, I am excited as you are, because I can't do it.
My best wish, and keep the fingers.!
Good luck!
This is something new, so, maybe it can yield desired results.
gyulasun
Quote from: a.king21 on June 09, 2019, 08:00:16 AM
Well firstly, in response to Rick's "phase conjugate mirror" claim.  Yesterday I ran the kit for 3 hours and the voltage on the gate driver did not move - so something interesting was happening.  (I had several extra coils). So I was lighting several leds and powering the gate driver without loss.
The voltage does not change (at least easily noticeably) on the gate driver because most decent gate drivers have under 1 Ohm output resistance and behave as a voltage source like a battery.
So either the AC output current from the gate driver or the resonant AC voltage across the L or the C member of the series LC transmitter (TX) circuit should be checked how they change when you couple some extra receiver coils to the L member of the transmitter coil.
What should also be known here is that if the series TX circuit gets detuned from resonance or you start coupling receiver coils
(with LED lamp loads on them) to the TX coil, then even if you carefully retune both the TX and RX circuits to resonance,  the impedance of the series LC circuit  (that loads the output of the gate driver) increases.
This manifests in a smaller output current from the gate driver and a smaller voltage level across the L and C members of the transmitter. (This latter is shown by Itsu and can also be seen even in Rick F's video, on their oscilloscopes.)
So you did not power the gate driver without loss, unfortunately, you misguided yourself by voltage measurement on the gate driver.  The "phase conjugate mirror" is a technical hodgepodge expression here, sorry to say.
By the way, from Itsu measurements and videos you should already have gathered guidance what to check and where.
Gyula
a.king21
Quote from: gyulasun on June 10, 2019, 07:20:32 PM
Gyula
Yes you are right. It is an honor to be mentored by such a great experimenter like you.   I would dearly like to see your builds.  I think I would learn a lot.  Anyway I have other projects to deal with now and will be leaving the experiments alone for a while.
And there are obviously no similarities between Don Smith and Kapanadze who are both probably frauds. And VAR is just an angle on a scope - nothing to see there  - move on. And I am sure that Kirchhoff's laws are immutable and work on every single occasion.
You have won Gyula.  Enjoy your victory. As you say there is no OU and no magnetic energy to speak of - it's all just a figment of Don Smith's imagination. And there is no increase of magnetic energy when you attach an earth ground, because the earth does not have any way of transmitting magnetic energy into a circuit.  And you cannot have a light bulb filament  made from bamboo cane either. Everyone knows that. After all the laws of physics are never wrong.  On that we can be sure. And of course there is no increase in magnetic energy when you activate a neon sign transformer or a pulsating HV module- everyone knows that.  After all you cannot get more out of a circuit than you put in because Kirchhoff's loop law is never wrong.
Enjoy your victory Gyula.
WhatIsIt
Quote from: a.king21 on June 10, 2019, 10:12:47 PM
Gyula is right!
But it does not mean that he want to destroy you. Continue your work and research. We need people like Gyula to show us our possible pitfalls!
So, don't just abandon idea. Try to expand it and find something new in there.
Every experiment needs and takes a time and effort. Who is trying, at the end will find something. That counts!
Good luck to you, and thanks to people like Gyula, they help with experience!
It is not about victory. Nobody wins!
Victory is BS until we all wins! It will come, sooner or later!
Cheers!
itsu
Wise words WhatIsIt,  nonbody here is trying to destroy anyone else.
For me its a battle between believes based on knowledge, facts and traditional education on one side,
and believes based on self tought experiments and (unproven) results shown in video's on the other side.
Both believes can be very strong.
But the result should allways be that at the end there is an "effect" that can create extra power and
can be shown and replicated and therefor measured.
So come on A.king21,  don't give up so easily, let Gyula be your guide pulling you back to mother earth so now
and then.    You (and me and others) can only learn from it.
Be aware of language barriers which can unintentionally cause phrases to come out different as originally meant.
Regards Itsu
