Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
What happens in seriell or parallel arrays network !?
Technical nothing special this concept :
https://patents.google.com/patent/WO2004100349A1/de
But energetical input versus energetical output. ?
Energetical input versus energetical output here : sjr ?
https://m.youtube.com/watch?v=M3YWB-noPNo
itsu
Trying to do a loopback on a 15F supercap stack feeding the gate driver.
FG still on 12V battery (plus 5V regulator), see diagram.
Supercap stack was first loaded to 12.5v using a PS.
I put 5 satellite coils each with their own schottky diode (Bat 46´s) bridge rectifier and puffer cap in parallel
to feedback the supercap stack.
First showing that the 5 parallel satellite coils can put up enough power to light up a 3W led (3.7V @ 60mA)
Then installing the supercap and feedback from the 5 satellite coils to this supercap.
Voltage starts to drop immediately no matter what i do like putting up additional load (input power drops) etc.
Video here:  https://www.youtube.com/watch?v=-jFIDUWkiys
All coils are tuned to 180Khz resonance frequency.
Hopefully A.king21, Benfr and ...... can repeat this loopback test with more positive results.
Itsu
a.king21
  Itsu:
2 points immediately spring to mind.  By using supercaps you are missing the Heavyside component  I would first try it with batteries and analyse the result over several hours if not days.
Secondly you are  not getting the energy from the electrons in the ground.  It is a hard concept to understand that the ground can replicate to and add to some extent the energy you already have.
Then we have to exclude mains bleed, because these circuits can pick up energy from your house mains wiring.
You also have to mess with the positioning of the coils because the magnetic fields emanating from the coils can reduce the input draw  as I have experienced.
Anyway I will look at your video in due course.
a.king21
Additionally you should move your coils away from the tX coil.  The way I understand it is like this:
If the satellite coils are almost touching the TX coil then it acts like a normal transformer.
If you move them out say 5 to 10 cm out  then the device acts like the Don Smith setup and you can duplicate the energy.
Also adding an earth ground  amplifies the energy.
This is what we are trying to prove.
gyulasun
A.king,
Yes I also remember what happened to Romero like you (but with small modification: he got ill when he was tinkering
extensively with Kapanedze-like setups and close to high voltage like Nelson).  (But this is a secondary issue now, I think.)
And I would like to add that there was a forum member here, very likely also from London, UK (where Romero was) and he knew (!) RomeroUK
name and  address and posted it openly in the same thread the Muller generator was discussed!  This member was a member on RomeroUK's
private forum too and was demanding  the "secrets" from Romero on that forum  but Romero refused him. I guess this event was crucial in the
final ending. So it is possible that  in this case the 'MIBs' were private grabbers from this or other forums reading his
address and visiting him.
Regarding your interest in starting the first tests for the looping, just remove the LED bulb from the output of a receiver unit,
build a full wave voltage doubler and drive its AC input by the receiver parallel LC circuit.
I just watched Itsu video and comments on his looping attemp. His 5 receiver units are not able to provide enough energy
yet to recharge the supercap. Very likely with more refinements and tuning he will get closer to unity.  Possible improvements
may include what Romero used for reducing diode bridge losses see his drawings here :https://overunity.com/3842/muller-dynamo/msg284131/#msg284131
Also, using a full wave voltage doubler which involves only 2 diodes (instead 4 for in bridge) can help reduce overall diode
losses but the ultimate improvement may come from using more and more receiver coils, with bigger sizes too.
If you have questions, I try to answer.
Gyula
Quote from: a.king21 on June 17, 2019, 01:31:06 PM
I have a very serious point to make sir....
What happened to Romerouk after he showed that self runner?  Do you remember?
I'll remind you....he was visited by MIB and threatened with his life and he was too ill to work for months after that.
What happened to Tinman after he showed OU on youtube?  His videos were taken down and he was visited by MIB.
What happened to Dave Lawton after he replicated Stan Meyer and disclosed you had to charge the capacitors for over 12 hours to condition them?  He was visited by MIB who seized all his documents.
What happened to Thane Heinz students after they replicated his trafo and showed it on youtube? I rang them up in Canada and they were terrified and denied OU (they didn't know who I was  ie if I was a government agent).
I also spoke to Lutec years ago and they were terrified and denied OU to me.
If Rick shows me a circuit - I will build it but you will never get a video. PERIOD.
This is not a game and Rick knows the line not to cross.  Re-read his posts.  He says so.
So please devise a test where the line is not crossed but satisfies the EE in you.  If me and benfr replicating but not showing a video is fine, then I am OK with that.
Kind regards...
EDIT:  How could I forget... What happened to Wesley (Stivep) and Kapanadze when they were together on a plane?  Both were poisoned on the plane and nearly died........  There is even a video Wesley took of kapanadze in an ill state.
