ARMCORTEX
The Chas Campbell debate is an interresting one.
But Mark D  is not in the know, his only source of information was Ashtweth and Ashtweth was gone after the Chas Campbell debate.
There is many systems out there that ressemble the Campbell device, some have build them bigger and bigger indicating to me that something is worth investing in.
He used an bouncing wheel as an oscillating sytem, wich is an interresting idea.
Other than that, the ideas I have put forward in my YT are some of the best.
noonespecial
Quote from: ARMCORTEX on February 17, 2015, 07:25:32 PM
How do you know this? Is it disclosed somewhere?
Low-Q
Quote from: ltseung888 on February 15, 2015, 04:58:41 PM
NO.  I want to lead-out gravitational energy via the unbalanced cylinder.  I want to use standard, commercially available motors and generators.  The equation is
Eout = Ein + (Egravity - Eloss)
I want to get a large amount of Egravity via the fast rotating unbalanced cylinder.
I assume you already know more than well that gravity cannot provide energy in a closed system.
So how do you want to accomplish excess energy output, or some how increase efficiency using gravity?
I don't understand, because as soon as you get viberations in the unbalanced flywheel, or what you use to "assist" energy output, the wheel does not follow a circular motion, but transfer its loss into mechanical viberations instead, and will therfor cause a mechanical phase shift that will try to stop the wheel from rotating.
Try this simple experiment:
Find a small electro motor, and put an unbalanced flywheel on it. Hand held, this motor will viberate when it runs and RPM will drop compared to if you fasten the motor in a heavy duty vise for example. Viberations will cause the motor to fight against mass "displacement" all the time, but instead transfer that lost efficiency into viberations.
What I can see from the original sketch, there is nothing but lots of loss in the system, making your device very little efficient.
Vidar
ARMCORTEX
https://www.youtube.com/watch?v=y6q_l6FpacU
https://www.youtube.com/watch?v=g_Z1S_1GlxA
He taps into the power used by these humans, humans are smart enough to not repeat and invest much money into something that bring nothing to them.
He is inputting energy by pulse, does he not release the holder  @ 39 seconds, is the Wheel not free turning @ 14 seconds.
Now Ive heard alot of crap comments but never have I seen or read the exact reason why he releases the holder.
Now we know, from our sims, that we get a secondary oscillation, could this no be used in an opportunistic fashion to connect and disconnect the driving Wheel
that sits on the wooden frame, free floating wooden frame.
Do not listen to comments, observe.
He first brings the Wheel to speed, then turns the screw then releases the holder, then loads the generator.
noonespecial
I think you forgot the Chas Campbell video... :)
Doesn't matter. I've seen it several times. Releasing the latch and tightening the clamp seems to be activating belt tensioners that may need to be inactivated to get it started.
I've heard it theorized that one (or more) of the wheels contain lead shot that will congregate after a certain speed and create the imbalance but this has never been proven.
There are several replications on youtube using only pulleys so where is the imbalance on those devices?
