0 Members and 18 Guests are viewing this topic.
stivep
Links to remember:
https://www.researchgate.net/publication/266887036_Input_Characteristics_of_Coated_Thin_Wire_Helix_Antenna
or more  accurate:
(a) Geometry of a monofilar helical antenna mounted on a large ground plane; (b) The image theory defined equivalent problem.
https://www.researchgate.net/figure/a-Geometry-of-a-monofilar-helical-antenna-mounted-on-a-large-ground-plane-b-The_fig1_266887036
more of  the same guy from link above:
Sulaiman Adeniyi Adekola
https://www.researchgate.net/profile/Sulaiman_Adekola
We are interested with image of coil and  the plane .
now compare  it with  image Fig.14 of J Corum
http://rexresearch.com/corumzenneck/US2017077715A1.pdf
All of the links  have logical  consequences
Wesley
stivep
Links to remember:
polyphase system for generating, transmitting, and distributing electric current as well.
https://teslauniverse.com/nikola-tesla/articles/nikola-tesla-3
Polyphase system  is used by J Corum ( patent)to restrict  theft of Viziv energy  transmitted by   use of earth/  air interface .
  Poly is  not Multi.
So   it is  particular phase  relation  that is mentioned   in Corum  patent.
references:
https://www.teslasociety.com/pdf/who_was_the_real_dr_nikola_tesla.pdf early corum paper.
Corum, Miller & Corum: Surface Waves TEXZON TECHNOLOGIES CONFERENCE PAPER [DRAFT DATE: March 23, 2016]
... 1988), the 60 Hz Ring Power Multiplier (1998, 2003, 2009, 2013), and the Polyphase Surface Wave Probe (2013, 2014, 2015),
and holds several dozen patents. He has authored over 125 technical papers and reports, and his principal ...
QuoteCorum, Miller & Corum: Surface Waves TEXZON TECHNOLOGIES CONFERENCE PAPER [DRAFT DATE:
March 23, 2016] ... 1988), the 60 Hz Ring Power Multiplier (1998, 2003, 2009, 2013), and the
Polyphase
Surface Wave Probe (2013, 2014, 2015), and holds several dozen patents.
Wesley
stivep
AlienGrey
Wesley hi, if any one is interested I have a schumann resonance design using 5 chips no shimmering micro only Cmos gives 7.825hz output if any one is interested I will draw out circuit and component list'
regards AG
