0 Members and 50 Guests are viewing this topic.
mkjekyll
No Viziv will most likely be using the technique Tesla came up with for encoding which is the same concept as Fourier transform, an analogue key if you will.  The defined power apex will require phase accurate leading edge tuning.  So one is either tuning to the Viziv signal or natural one.   Some smart folks may figure out how to hack the VIziv receivers so they don't require Viziv but pulling power from both sources would be like trying to sync to two different master word clocks.
We are like ants pulling power from that interface.  Some huge oversize Hoover damn size undertaking could pull too much and likely cause some problems with P waves.
groot
Quote from: stivep on June 21, 2019, 07:21:03 PM
Picture at the bottom right is showing original Seneca lake recreation  of Borrows experiment from 1936.
In 2014 J Corum. used equipment   Tx( green color)  Rx  (orange)
The  Viziv tower is marked  correspondingly Rx/Tx
So if  you  know  what it is  you can make the same
progress.
https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf
Фотография справа внизу показывает оригинальный -Сенека озеро воссоздание эксперимента Борроуз 1936 года.
В 2014 году Дж. Корум. использованное оборудование Tx (зеленый цвет) Rx (оранжевый) Башня Viziv
обозначена соответственно Rx / Tx.это что вы можете
Wesley
Rx orange marked by you is a dipole used to generate Norton wave compered to zenneck surface wave in this experiment.
they were on a boat and i doubt they used it for receiving power. they measured field strength and i believe they used different type of equipment.
Thank you and waiting for more important information .
ps.
I need relative permittivity and conductivity of distiled water at 1.85 Mhz .
Im flexible on frequency Thank You.
saturnio
Hi guys, I don't know if in the past you have been talking about this patent, but it is really interesting. It talks about harvesting energy from Schumman earth resonances as a metod of energy conversion proposed by Wesley. It use a Tesla Coil and and a ground system antenna. Also the patent has cited other importants patents.
"Power receiver for extracting power from electric field energy in the earth"
This is the company: www.earthenergies.net
"The Company's patented technology integrates state-of-the-art electronics with newly discovered geodynamo-based low-frequency subsurface electromagnetic wave energy, into scalable electric power delivery for residential and microgrid applications"
stivep
Quote from: saturnio on June 22, 2019, 10:34:04 PM
I have analyzed   patent from Earth Energy  and
I think that  it will  be  the  best if I make video about it.
There is some interesting material  there.
http://www.freepatentsonline.com/20150102675.pdf At  link shows  that is not secure.
so go here:https://patents.justia.com/assignee/earth-energies-inc
but that doesn't give you any good
the best is direct here:
https://patents.google.com/patent/US9564268B2/en
Wesley
AlienGrey
Wesley dear friend, I see some have found this article, I wonder if any one person has found a way of actually generating that schumann frequency of 7.85 hz with division of available crystal devices or modules with out
ending up with a pile of trailing digits below the decimal point. Thoughts any one ?
regards AG
