The solution !!!!
Started by efusystem, June 10, 2019, 11:48:24 AM
forest
I also think we don't need ground. Maybe it has some beneficial effect like delaying signal or shifting phase or else like in Tesla coil
NdaClouDzzz
Quote from: forest on December 12, 2020, 03:33:54 PM
Greetings, forest
IMO, it all depends on what kind of FE device. For example, most of Don Smith's devices obtain their FE from harvesting electrons from an air or earth ground. Many other so-called FE devices are not clear on where they get their FE from, so it's not so easy to know if an air or earth ground is needed. Electrostatics are my area of interest with regard to FE. If people would just stick to something simple like harvesting electrons using a simple device such as demonstrated by Lorrie Matchett ( https://youtu.be/Kdup42Epq0o ), then they would have the foundation for all of the FE that they could ever need. Instead, most just look at a simple device like that and dismiss it as being nothing. They want big power NOW, not realizing that they need to start with the basics first. There are too many people on the forums intentionally and unintentionally confusing things. Charging by electrostatic induction! ( https://youtu.be/pJ36EtABLAk ). That is all any newb needs to start with. Once they grasp that then everything else is just improving functionality and power output.
Cheers.
aether22
Quote from: conradelektro on August 24, 2020, 07:23:36 AM
To Efusystem:
I do not doubt that the "systems" described in the PDF-File "EFUSystem" generate spikes of high Voltage and very low Amperage.
I play a lot with electrostatic generators (electrophore, Wimshurst Machine, Triboelectric effects) and can also generate such spikes...
Well, you can collect the charge from say a Wimhurst into a capacitor and discharge into a resonant circuit...
If it discharges into a many turn coil than transforms into a step down you can get real current also.
At any rate the more interesting fact is that you can make elecrostatic devices work as devices that compress aetheric energy as they do for electrical.
If you do this then you will have a shot at Free Energy or other interesting effects.
But the key to doing this is to input some "aetheric" energy, just as it works with some initial electrical charge and increases the voltage, you input some initial aetheric charge and it amplifies it.
This is possible because what I am referring to is aetheric energies that mimic positive and negative ions but at a subtle level, I can show you how to create an initial charge easily.
NdaClouDzzz
Quote from: efusystem on June 10, 2019, 11:48:24 AM
Thomas Townsend Brown discovered in 1929 that a charged capacitor experiences a push towards the positive side.
Anyone can check this in a laboratory.
AC Capacitor: A Water Tank Analogy https://www.wisc-online.com/learn/career-clusters/stem/ace4803/ac-capacitor-a-water-tank-analogy
Bob Smith
I keep wanting to go back to very simple principles:
- Ambient powered resonant LC circuit
- Step up coil
- Step down coil
The Lahkovsky apparatus has always intrigued me because it seemed to be able to harness ambient (aetheric) charge for healing purposes. Could we not do this to power an LC circuit?
Bob
