RANT CAFFE ASYLUM
Started by WhatIsIt, September 06, 2020, 10:09:59 PM
ramset
V8
Dr AG is original source of Floyd Sweet and Bucking coil info to Chris ?..and never replicated anywhere else since ? [many,many years Now ?
is this accurate to write [aside from recent Chris hidden claims with batteries and power supplies]?
or should not be written here ?[I will remove comment ?was written here before but not sure if removed...
Thanks Grandma
v8karlo
Quote from: onepower on September 26, 2020, 02:54:24 AM
V8karlo
I use two supercap banks I made rated at 5 Farads /24 working volts, 30 volt max. So I know the exact input versus output with a simple calculation U=1/2CV^2. It's also easy to loop the output cap back to the input cap with a high efficiency buck converter.
So it's actually very easy to loop a circuit and I gave up on trying to use my DSO to measure complex HF waveforms years ago. It's basically a waste of time in my opinion.
Think of it this way, you could spend weeks using all kinds of expensive equipment trying to analyze input vs output. Or use two cap banks or a loop and know in minutes. So why dork around when we can know for sure in a matter of minutes?.
Looping the device has one wonderfull thing.
Voltage from source and voltage from feedback loop will equalize,
when met together, removing all hash and leaving
only one variable to deal with
currents.
Equalization will not affect only voltage, but all kind of things,
and currents will adapt accordingly.
By observing current from source and current from feedback line,
imediatelly is seen how much is going into circuit and how much is returning
to circuit.
By comparing two currents it is easy to see real cop with more than 99% accuracy.
And there is no room for error.
And there is no need for complicated procedures.
Everything is visible at once.
To avoid overvoltage in case of overunity, simple zener to shutdown pin of
controller is sufficient to stop desaster.
This is simplified view, but more like block diagram explanation.
This method removes all unnecessary pitfalls.
Loop the device is ultimate test.
v8karlo
Quote from: ramset on September 26, 2020, 11:36:51 AM
V8
Yes, Chris found out from Dr. AG about bucking coils,
and material on Floyd originate from Dr. AG,
who is in Patrick Kelly book also.
Dr. AG team did extensive research on bucking coils and after
lots of time spent, and money, they gave up.
I wont go in details, but they tried everything.
That does not mean that bucking coils wont find its usage somewhere.
That means that with good funds and educated researchers they did not find
anything sifnificant!
In short.
Some pictures of bifilar experiments are not from Floyd as Chris claims,
but from Dr. AG team researching possible variations of bifilar and
bucking coils in order to find cause of effect from Floyd device.
Chris is mixing Floyd stuff with separate research of Dr. AG,
thinking that it all originates from Floyd.
But it isnt.
seychelles
ONE POWER IS ABSOLUTELY CORRECT. WHEN ELECTRICAL FREE ENERGY WILL
VERY SOON BE DISCOVERED, IT WILL BE VERY EVIDENT AND WILL NOT NEED ANY
SPECIAL MEASURING INSTRUMENT.
NickZ
  Selfrunning, YES!!!
  The rest is just an illusion... an ego jack off, you might say, for EMJ.
   But, it won't light your house, while it may be more efficient, at best. Self running, I doubt it, after all this time.   If so, let's see it. Cause, I don't believe it's worth the time of day, and months of playing games.   NEXT...  as this is just a diversion, so that someone can keep dreaming about making some money, from us "stupid guys", here.
   NickZ
