Thanks to ALL for your help!!
RESSURECTED TINMAN NEW INVENTION.
Started by seychelles, December 18, 2021, 10:54:04 AM
partzman
Quote from: captainpecan on December 22, 2021, 11:52:18 AM
I have been kicking this statement around for a couple days now while I wait for materials to test things. Even though his statement seems impossible because the two characteristics oppose each other. Is it possible that he may have been simply referring to the use of multiple coils in series and it is simply perspective. For instance... when he is referring to a coil of low inductance, could he be referring to just each coil individually. Yet when he is referring to high resistance, he is referring to the multiple coils in series and actually talking about the whole circuits resistance? The low inductance of EACH COIL will allow the quick on off pulse time as it reacts to its ratio of turns (inductance) to core permeance, while from the perspective of multiple low inductance coils hooked in series the resistance increases more and more for each coil added further restricting the current. It's a possible way to satisfy both conditions he says is required at the same time. Understanding that this method would still produce a higher inductance for the series, each coil will have its own lower inductance. Just a thought.
One way to double the resistance for a given inductance is to apply Lbuck = (1-k)*2*Lpri when the windings are equal inductance.  For example with K=.5, if both windings are 5mH with 1 ohm resistance each, then Lbuck = (1-.5)*2*.005 = .005 with a total dcr of 2 ohms.  So, two identical coils connected in a bucking mode with a coupling or K factor of .5 will yield a total inductance equal to each individual inductance but with twice the resistance.
Pm
Floor
My build...
          Not a replication.
                   but
            A test bench.
To measure static magnetic force at several diminishing distances.
          and
arrive at the total kinetic energy of the motions,
                 not the peak force only.
i.e.
1.  To measure the energy present over the course of travel of a
ferrous plate in attraction to and rotating toward and then into, a centered
between two neo magnets position.
2.  To measure the energy present over the course of travel of a
before one neo magnet position.
I have two balanced fly wheels.
One is iron, 7 inches in diameter / magnetic interacting, the other is of a zink alloy
and 6 inches in diameter non magnetic interacting.
I intend to use the non ferrous fly wheel.
There will be other variation of / measurement sets later.
Also hopefully a linear motion / energy measurement set, yet later.
Lets measure and narrow down the variables.
         floor
Floor
progress...
I just spent two days on a dead tree removal job..$ income...
I'm still assembling materials / working out the design.
            I have
the fly wheel
two ball bearing sets of an appropriate size
an axle of an appropriate size
I'm thinking to do a horizontal axle design
with a       degree indicating scale      printed upon the fly wheel.
The fly wheel will also serve as the pulley upon which weight objects are
sequentially suspended in descending increments of weight, as the steel
plate is rotated farther from the magnet/s.
Break away from the magnetic attraction force will be caused by the pull
exerted by the weight objects.  The pull force needed to do this, will be determined
at multiple increments of distance of the steel plate from the magnet/s.
  best wishes
      floor
ramset
And a happy holiday to the Tinman and the very loud fisherman !!
And all who toil "in this thing we do" for a better world!!
With gratitude
Chet K
Thanks Grandma
seychelles
DITO RAMSET. MAY THE ETERNAL LIGHT AND FORCE BE WITH YOU AND YOUR FAMILY.
