nix85
There, he again resorts to adhominems and links generalities i have seen all, and to his old posts, why am i not surprized.
In case you have not noticed few posts back i analyzed his key video about his "theory", and have analyzed
their "demonstration" which you also never addressed. I have watched all their videos, read their webpage and facebook page.
In case you're too lazy to do any of your own research, here is my research from few posts back, repost.
In addition to recently surfaced leaks of the insider, i already addressed their 'demonstration' of supposed 2.5kw in 20kw out, not very convincing at all.
"We got some load on right now" he says and points to the bulbs.
https://www.youtube.com/watch?v=AkwYCpFMP8w
Test load we see are 12 incandescent bulbs. 20kw load? And when asked about this discrepancy they reply in the comments
"The 12-incandescent light bank is only a part of the load. There are also motors, transformers, capacitors, etc.in that load bank calculation.".
Well, capacitors are not a load, transformers neither except for the losses unless they are loaded with actual load, neither are motors unless they do work, free running also only consumes for losses.
This is not how you do a proper OU demonstration. It should be done in clear space without cables all around, device should not be plugged into the wall at all, load should be clearly shown, not just few bulbs in the background that don't amount to 1kW and claim 20kw.
And his "theory" is ridiculous.
https://www.youtube.com/watch?v=Nm1VJ65LcXM
His whole "theory" is repeating the most basic facts that iron atom has
4 unpaired electrons and thus has a net magnetic field (perfectly explained
in the canadian documentary from the 80s i linked number of times already).
And then he says how electric steel amplifies flux of a coil "4-5 times" and he
claims this is 5x overunity. That is his whole "theory", that iron is ferromagnetic
and that it amplifies flux. Firstly, electrical steel does not amplify flux 4-5
times, but 4-5 THOUSAND times or more, as table below shows permeability
of electrical steel is up to 20,000 and other materials up to million.
Secondly, altho i strongly believe high permeability cores are great potential for
overunity, using them as ordinary transformers is no overunity. The other day
i again shared my idea for high permeability core flyback transformer and pix
corrected me rightfully that altho small current in the primary is enough to
establish very large flux in the core, the reverse is also true, small current
in the secondary is enough to counteract it (lenz). I admitted back there
that i omitted this important detail. I also wrote there is more to it, for
there are countless reports that backEMF yields overunity, altho it is usually
not much more than 100%. So, IF Holcomb is really getting 5x overunity,
it is surely not by mere fact of iron's permeability, he is either using
screening foil for the secondary like Alexander Mikhalych and others
to divert the lenz and possibly resonance too, and/or delayed lenz ala Heins etc.
There must be SOME method to bypass the usual 'walls'. And, again, IF
he's getting what he claims, he surely did NOT disclose which method he uses.
Now, if you have something intelligent and concrete to say for a change,
address these points.
Which exact mechanism do you propose he is using, one of these i suggested
"screening foil for the secondary like Alexander Mikhalych and others
to divert the lenz and possibly resonance too, and/or delayed lenz ala Heins"
Or something else.
And what about their "demonstration" 2kw in 20kw out where only load we see is
12 lightbulbs.
I have already discovered the "technology" and unlike you suggested some possible solutions.
Try to do the same. Here is some music too, pop on the earphones and think
https://www.youtube.com/watch?v=5nE3ycSevIA
Enjoy!
SolarLab
Give it a rest you idiot!
All of your concerns can be easily addressed yourself if you simply took the
time to look into them; that is if you were capable - but apprently not.
Like I said - appreciate the technology:
https://www.facebook.com/holcombenergysystems
Review the links and videos.
https://holcombenergysystems.com/
Review the technical discussion and videos.
Or, follow the posts (solarlab) starting here:
https://www.overunityresearch.com/index.php?topic=4261.msg98509#msg98509
And, as you discover the technology, put on your over-the-ear headphones:
http://radio.garden/listen/power-smooth-jazz/UpXKkkbb
Enjoy!
Yea, I know, don't feed the Trolls - but hey, they have to eat and feed their dog!
BTW - I give more to charity than most people - Trolls included (but at least
in this case it's not out of my pocket)  :D
rakarskiy
Speak to the point!
How to spot a troll? He does a lot of garbage without real indicators and experiments, in which you can freely get confused.
For those who want to repeat Holcomb, they must know exactly how the traditional synchronous machine works.
He gave his recommendations in two posts:
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg578772/#msg578772
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg578688/#msg578688
To see how the power windings of a three-phase (4 pole) synchronous generator are wound is not difficult. If you already have such a stator from the generator, it remains to make a solid state for it, everything is in Holcomb's patents, I gave a feature in the recommendations.
By the way, everything is confirmed as never before.
My latest test demonstrates this. The reverse pulse works on the same principles as the phase of a synchronous generator.
I hope to finish my material soon.
PS
"Reverse convector Rakarsky" is connected to a slightly discharged battery 12V, 7A / h. The same source is used to control the convector circuit through a common circuit. The oscillogram is taken from a 1 ohm resistor, through which the system is connected to the negative terminal of the battery. Waiting transformer from a microwave oven was used, the windings were rewound and the magnetic circuit was modernized. We get OverUnity, only if there is a zone for charging the battery, if the battery is charged, then 0.89-1.
Analysis of the full period: B - half-cycle of excitation; C - reverse half-cycle (generation); A - zone of Unity of two half-periods.
nix85
There is no rest for liars, you turboidiot!
You have wasted too much people's time and energy with bullshit.
You are incapable of answering any question relating to the subject, always sleazily dodging,
llinking the same stupid links which supposedly "have all the answers", at the same time
accusing people of being "trolls" and "lazy" cause they dared to ask - anything.
Now, since it is clear i am talking to a bot which possess no intelligence, not even an artificial one,
i can only suggest your creators, try harder, cause like this it's laughable, pathetic really.
Look at ChatGPT, it at least simulates intelligence at times, you should improve it so it at least
tries to mimic an actual intelligent human being. Spambots are easy to spot these days,
filtering is done mostly automatically.
Google AI Library, you will find tons of premade algorithms that will be somewhat harder
to spot, you can even customize ChatGPT as a shill-bot, with bit of effort you can
achieve far better results. You can even add music to them.
https://www.youtube.com/watch?v=nFp_2eJlfYg
Enjoy!
PS using only real human agents might be a wiser option, bots are too easy to spot and destroy
(altho your 'human' agents are hardly any better) :D
nix85
There there, when you're proven wrong just say "troll", how sweet.
It is clear who has been posting garbage without real indicators and experiments, which i surgically removed.
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg578769/#msg578769
There should be no induction here he said :) And imagine, induction happens perfectly normally in 2 ways.
Not to mention other pearls "in the groove of the generator, the magnetic lines do not cross the wire to induce the EMF" :)
And all the rest.
