The Deaf Were Not Able To Obtain The Dr. Flanagan Nerophone To Begin Hearing
Started by russwr, August 03, 2023, 09:56:20 PM
sm0ky2
yes, as i stated in my video, resistors will perform a similar task
but for the application, analog signals are more suited for the human ear
and also with biotech we always want to use the most energy efficient methods
sm0ky2
Quote from: rakarskiy on August 05, 2023, 04:38:33 AM
[/size]
Also the scheme of the simplest device for bioresonance vortex medicine. The transmitter is a bifilar tesla coil with an inner diameter of 25-30 mm. It is connected in capacitance mode: one wire on the outside, the other on the inside. Important!!! That the natural frequency of the bifilar coil was within 300-350 kHz. The input signal must be processed so that the lower potential does not fall below the value at which the coil's own resonance collapses.[/size]
very critical. Important to make note of these things
The important thing to understand about this circuit,
The 3 capacitors drive the harmonic of the resonator's frequency
which is also grounded on the back side
If i were to make this i would replace the 3 caps with coil capacitors
Throw the resistors away and use smaller tuning caps in parallel to each
of the coil capacitors. (these are just coupled 1:1 inductors, usually made from pancake bifilar pairs)
you aim for the proper inductance to resonate at the 3rd harmonic
then adding parallel capacitance can tune the frequency by increasing the impedance
you could drive the circuit consuming almost no power
most of the "work", in terms of electrical consumption,
would be done by the incoming signal
kolbacict
I made the generator like in that picture. The electric lamp was having used !
Nothing interesting. In addition, this design is used at frequencies of kilohertz, tens of kilohertz.
Doesn't work well at higher frequencies. Every single RC must shift frequency in 60 degrees.
Using three separate adjustments doesn't make sense.  What is frequency  used in Flanagan"s device?
Quote from: kolbacict on August 12, 2023, 01:54:00 PM
https://patents.google.com/patent/US3393279A/en
To read,function dependent : 20 - 200 kilocycles/KHz l
http://www.rexresearch.com/flanagan/neuroph.htm
rakarskiy
