new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
hartiberlin
Hi Richard,
if you can get it down after some first production runs to
around 1 US$ per Watt that would even be better..
Surely the first run will be sold more expensive
as it is in most cases, when new products surface.
Well, I am amazed, that you can generate now power from
a stationary coil.
Is it now some kind of overunity transfomer, where you feed
in some small wattage and get a bigger wattage out ?
So in this picture:
the very left unit was actually a generator and not the drive motor ?
Then just the small copper coil was the pulse motor with the
black plastic-magnet wheel below ?
Many thanks for answering and the video was
really impressive powering all these
loads from a very dead battery...
Regards, Stefan.
hartiberlin
P.S. Hi RIch,
have you been able to run your units yet just on charged capacitors
insteadof needing a lead-acid battery ?
So can they power themself without a battery ?
Many thanks.
Doug1
hartiberlin
Hi Rich,
was this unit:
Just also only using the electromagnet to propell the black plastic-magnet rotor
and the axis of it drove an alternator to produce current for the battery ?
So you needed less power for driving the electromagnet than the alternator
puts out ?
Can you please verify this statement ?
Many thanks.
Regards, Stefan.
magnacoaster
ok i was trying to understand some of the questions and i see where the problem is  there is no gen hooked up period !
we are using the motor to run and charge the battery period see attached pic.
we have not used caps as there not recyclable and explosive when they blow as my lab has no windows it could get pressure
and i don't need to bleed if one blows.
Lead acid is the way to go as its recyclable. and its about making it green is it not ?
the next unit has no moving parts other then the oil pump as it moves the oil. We had a set of points that was used to control the power but i was able to build a neat little circuit to replace that as it had a bit of noise and was making me crazzy in my lab.
i am also working on a new box to hold all the parts so the unit for the house can be used as well in the car or truck.
only difference in the unit is the output boards as i can limit the power out these boards.
These will be sealed in epoxie so there will be no way anyone can make any changes thus i have no concerns about customers getting in and changing things.
Richard
