new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
hartiberlin
Regarding the  picture:
So did you just switch off with the electromagnet the magnetfield of the
neodym magnets behind it, so you could control the repelling of the
rotor magnets and thus turn with little input power the rotor
to generate power with the alternator ?
hartiberlin
Hi Rich,
our posts just crossed.
Please do a reload of the page
cause I was refferring to the older unit.
With your newer unit shown on your current youtube video:
with the 2 white plastic motor/generator ? combinations,
which one is the motor and which one is the generator ?
Is the smaller white right disc the motor and the bigger left one disc the generator ?
Many thanks.
magnacoaster
i see where you are all confused as i understand now where you have been looking
we do not have a gen as in the regular meaning we use a coil and magnets it
changes  the voltage, Amps and freq. of the power its a single coil with a magnetic feil wrap
we inject power in and also pull the power off on the same line.
we have the patents pending as well as a few addons
Richard
the old unit used the rotation to run the timing only it had the big wheel as a weight
so that it had a constant speed. the single coil is all you need as the round logs are only 35 % efficiant
our unit seems to make lots of power more then we can pull off. the problems we have had
made me a little nuts as there have been a few !
hartiberlin
Quote from: magnacoaster on February 18, 2008, 10:42:24 PM
Hi Rich many thanks for the answers.
So what is a magnetic feil wrap ?
Is it some kind of magnetic particle wrap around the coil ?
Richard
As you now have secured it as a patent,
maybe you tell us a bit more about it or
show at least a new video of the new unit ?
I see.
I had another look at the cables on the big red case device with the one coil
with neodym magnets behind it and the black magnet wheel.
It seems the electromagnet is just energized only via the 12 Volts battery
and the contact points in this unit.
So it seems you just only pulse the 12 Volts from the battery through the
electromagnet and then it drives the wheel
and at the same time comes out the
BackEMF of the coil and produces your huge output ?
So you probably also rely on the sparking
of the contact points..right ?
Does your new solid state unit also has such
a sparking on-off-switch for the coil ?
As we have seen in this thread:
http://www.overunity.com/index.php/topic,4124.0.html
you can generate a huge amount of BackEMF energy
via a sparking contact from the right coil,
I wonder, if it is not the same principle in your case
also amplified, cause you have stacked even the
neodym magnets onto the core...
So these things are probably the same and you just have
only multiplied it with using these very strong neodym
magnets still on your core..
Many thanks.
Regards,Stefan.
magnacoaster
i watched that video the only problem is he will make the magnets brittle due to the power going into the magnets this was not a great idea.
no i do not have to use spark gap it will run on the new timing device just fine
we use the vortex's off the magnets to drive the voltage and amperage  higher
i will shoot a video this week as i hook the unit all up ad run it for a few days here in the lab maybe
i can even get a  live video feed going so you can watch the unit in action.
right now i am so swamped with all the suppliers i have to deal with to get our
production run ready to go and the new shop setup and running.
yes some times there is more to life then living in my test lab
Richard
