Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
Bruce_TPU
 :)  Bingo...
I think brnbrade has found some missing ingredients!
Awesome Job, brnbrade..!  More Erfinder, eh?  LOL
Cheers,
Bruce
brnbrade
chrisC
The initial reading was of 50v without the ring magnetic permenente.
But, when I put the ring permenente the things left my understanding.
The frequencies were of an old walkmam. The frequencies were of the sound that run of the station tuned in place.
Yes, a transformer, high speaker, the primary vibrating in magnetic field, secondary as collectors.
Tks
brnbrade
Hi
I believe with more amper and faster and broad pulses the thing begins to be interesting.!
In it lives him.!
regards
chrisC
brnbrade:
Thanks indeed. So, you have a old walkman which tuned to a specific AM/FM station of a certain frequency and the output of the jack which would have been connected normally to a headset is not driving your primary coil. Both your primary/secondary are wound around this PVC pipe with a magnet shuffled into the hole of the PVC pipe?
That's seemed really simple. Please confirm your AM/FM station freqiuency. Thanks
Chris
Bruce_TPU
Hi brnbrade,
So you input the frequency with a wire from the headphone jack, and not connect the ground?  I heard a story similar once, except that person used his headphone and put it right on the input.
And the Walkman was tuned to AM, FM station, or just static noise?
Yep, Chris asked my question! LOL
Cheers,
Bruce
