Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
Earl
Hi brnbrade,
please comment on the attached image and the questions in it.
Thanks and 73, Earl
brnbrade messages, sorted newest at top.
06:13 24 June 2007
Hi, The permanent magnetic ring on the outside of the pvc tube. The station was FM stereo.
More thinks that is relevant.
Mine to think it is, the primary works as electromagnet of the pulses of the sound frequency.
A diode rectifier was put in the outlet of the walkman for not having tension return.  Tks
05:50 24 June 2007
Hi, I believe with more amper and faster and broad pulses the thing begins to be interesting!
In it lives him!
regards
05:37 24 June 2007
The initial reading was of 50v without the ring magnetic permenente.  But, when I put the ring permenente the things left my understanding.  The frequencies were of an old walkmam. The frequencies were of the sound that run of the station tuned in place.  Yes, a transformer, high speaker, the primary vibrating in magnetic field, secondary as collectors.  Tks
05:06 24 June 2007
My TPU comprise in 24 turns medium wire  and 1000 turns more fine wire in parallel, mounted in pvc tube and isolated well isolated. I put permanent magneto ring in turn of the tpu and reader  jumped as crazy above the 250v.  TKS
04:14 24 June 2007
Hello all, This morning I played with resonant frequencies of my walkman in the ring tpu that I built.
I input whit 2 cells 1.5v, and collect 52v 1A in output.  When I decided to put a permanent magnetic ring in turn of the rings collectors and...
Amaze, the readings jumped for more than 250v. with two cell my reader was crazy.
I hope help, Regards
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
bob.rennips
http://www.forcefieldmagnets.com/catalog/product_info.php?cPath=23_37&products_id=66
This is the largest ring magnet I can find, poles on the flat face - which I believe is what is required. Still waiting for confirmation from brnbrade on this.
http://www.rare-earth-magnets.com/SearchResult-CategoryID-33.html
Some more here. Seem to be cheaper. Also have different N-S arrangements for the rings.
Microwave magnetron should have two large N-S on flat face, ring magnets.
FROM EARL:
Ring magnets are usually used in loudspeakers.  Should be able to be found in lots of places.
Try:
http://www.engconcepts.net/List_Of_Ceramic_Magnets.asp
http://www.engconcepts.net/List_Of_Cone_Magnets.asp
http://www.supermagnetman.net/index.php?cPath=41
he has everything, lots of N50 material hehehe which will pull in an aether vortex from the next galaxy.
I suggest trying both neo and ceramic materials.
bob.rennips
More things becoming apparent. BrnBrade mentioned STEREO from his walkman.
Stereo signals work on phase difference to provide the illusion of the sound source coming from different points (sound stage). If he was feeding two signals into his coils, that were stereo, he would have near identical signals, but with subtle phase differences.
This matches with patent. Quick succesion pulses as per the patent would be equivalent to a small phase difference.
z_p_e
Quote from: bob.rennips on June 24, 2007, 11:10:55 AM
Now moving to what Otto is doing.
I hope everyone sees the parallels between Otto having two different sized (different diameter), 1-turn coils and the concept of dual magnetic flows moving at different linear speeds.
This is the key effect I think we should all be building on.
Bob, these are shorted loops. I wouldn't consider them coils per se. As such, they would act more like antennas then coils.
Darren
bob.rennips
Quote from: z_p_e on June 24, 2007, 11:46:43 AM
Darren
As shorted loops, acting as antennas, that would mean peak current would flow at resonance ? So when both loops get hit with their respective resonant frequency, you would have some sort of dual magnetic field flows, interacting/cancelling due to the 'mobius' twist ? Antenna theory is not my thing!!
What is the difference in terms of magnetic field flow between a cyliner magnet and a ring magnet. The only thing I can see is the dual magnetic flow aspect.
