all you need is spead diode to make tpu bealivet
Started by MACEDONIA CD, June 02, 2007, 03:57:49 PM
MACEDONIA CD
make  simple  primar  and secondary colector  coil  and  push  whit  250 khz  and dont  wory   than  make simple  ac/ dc converter  whit  20000uf  capacitator  whit spead diode  whit  small resist  .than you get something very good  ...
         bealivet   make  that  and youy whel see ............................................  input energy  whil be  small   ,and  out  coil the energy  can be 10 times  beger than input energy
           if you dont now how to make   all you need is to send me   you  email than i  whil  ansver to you how to make  1  off this  divices    i m here  to help  to anderstend   i to make  this  simple divices    ho  is very hard  to anderstend  you  dont need money  much  to build  this   ,,make   and than  tell my  what  you are  mean for this   ......     AKO IMA  NEKO KO RAZUME  YU JEZIK    NEKA  KAZE  ILI PITA  U VEZI SA TIME    TU SAM  DA POMOGNEM  DA RAZUMES  ILI NAPRAVIS  TAJ   TPU
                              ZDRAVO     .....''''''''''''''.......
FreeEnergy
make a video/graphical tutorial demonstration on how to build this thing already...then just post it here... thank you!
peace
Bruce_TPU
We are happy to hear the report.  Please help us with the TPU.  We would love some more information and details.
(Is this the man referenced in SM's post today by Lindsay in his story?  Macedonia is a small country indeed...Hmmm....)
Blessings,
Bruce
gn0stik
Quote from: MACEDONIA  CD on June 02, 2007, 03:57:49 PM
DISAMBIGUATION
Make a simple primary and secondary collector coil, and drive it at 250Khz, and don't worry about anything else. Just make a simple AC/DC converter with a 20K uF capacitor, and a high speed diode with low resistance. Then you get some very nice results.
Believe me, Make that, and you will see! Input energy will be small, and output energy can be as much at 10 times the input. If you don't know how to make all of it, just send me an email, and I will answer you with instructions on how to make one of these devices. I'm here to help you guys understand. I want to make it simple to build this device, which until now has been very difficult to understand. You don't need much money to build this. Just build it and then tell me what your results were.
-- macedonia gibberish(to me anyway) --
bob.rennips
Great work. Thanks for sharing. Blagodaram.
This is interesting. Could you see if I understand what you are saying correctly. Thanks.
Macedonia, could you let me know which of the points below are right and which are wrong. Please advise any mistakes I am making in my understanding.
1. You make a coil with a primary and secondary.
2. The coil does not have a magnetic core, it is an air core.
3. You connect a 250khz ac sinewave? to the primary.
4. Connected across the secondary wires is a 20000 uF capacitor.
5. The speed diode is connected in series with the load such as a lamp or bulb.
6. The power, voltage and current, across the lamp or bulb is greater than the power going into the primary.
Some questions ?
1. Is the coil solenoid or toroid or does it not matter.
2. How fast is the speed didoe. Is it less than 100ns ?
3. What diode are you using ?
4. What type of capacitor ? Eletrolytic, Mylar, Polyester, Ceramic etc.
5. Do you get a higher voltage than expected or a higher current than expected or higher voltage and current than expected.
