all you need is spead diode to make tpu bealivet
Started by MACEDONIA CD, June 02, 2007, 03:57:49 PM
MACEDONIA CD
ok   HI    this circuits   is  not  a  have make   R E A D  PLEASE   I GET MORE  >>>>>>>> POWER   I MEAN  WATT  IN OUT  COLEC. COIL  ,A NOT  BIGER VOLTAGE   <<<<<<<<<    I SAY  A BROKE   BULB  25 WATT 12 VOLTS   ,,,,,   WHIT  8WATT INPUT ENERGY  .......     DO YOU ANDERSTEND    A SAY POWER  I MEAN  WATT  NO DUBLE VOLTAGE
Bruce_TPU
Thank you Macedonia,
Please draw a simple circuit including the pieces you are using and post it here.  It will make it easier to understand.  If you need help with this, please let us know and one of us will attempt to assist you in drawing it.
Thank you,
Bruce
FreeEnergy
Quote from: btentzer on June 06, 2007, 03:29:19 PM
Thank you,
Bruce
i already said that, but i don't think it's going to happen.
so far all i see is empty claims.
wattsup
Received this message from Macedonia today.
I had asked him about his speed diode.
I think we will have a communication problem. I sent  him an email but I think he cannot understand or it is neither here nor there. But there is a problem in communication so if there is anyone that speaks Macedonian, we need your help.
QUOTE
HI this is macedonia cd ... sory wor my reply but i whant to say to you ,,, this diode its like the figure like ordonery BUZ11 tranzistor ,,,
in this object is a 2 diode i have make 4 duble diode as 1 and i have a ac/dc convertor but
this diode you made find in the power suply in the PC comuters in this box power suply is 2 diode ho is have small resistance
BY THANKS
UNQUOTE
Bruce_TPU
@ everyone
I recieved further instructions as well from our Macedonian friend.  Perhaps some one can understand this and try a replication:
Cheers,
Bruce
Message:
HI    IF YOU WANT  TO MAKE THIS
  YOU GET  SOME  SPEAD DIODE    YOU CAN FIND IN THE  POWER SUPLY IN THE PC COMPUTER   IN THIS BOX  YOU CAN FIND  2 DIODE WHIT  A CASE  LIKE    ,,,   BUZ 11A,,,  OK  THEN YOU  GET  A 20000yf  63v  capacitator    .....
  then you  make simple  ac/dc  convertor ..
  then you make simple  tpu whit primar   and  secondar  colector   ho is conected  to a ac/dc converter   then you  bring a  250Khz  impluse  ho is not a  sinusoide votage  ,,  in the primari coil
  you make  6 inces colector coil     then around this  coil   make  about 20 turns  coil
