Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
ashtweth_nihilisti
Hi sevich, as i know you personally, and you actually build things to verify them  ill send you the direct copy of his gravity wheel instructions the edits are still being done tonight.. We will publish them here, i already posted about his wheel.
Its a shame we have so much crap to sort through thanks to Hum, you may have seen that we stated that his wheel based on what he showed us could rotate just using gravity, the only problem is it wobbles due to it being made of un robust materials and de tunes, how ever you and others could fix this.
Plans and vid is coming
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
Quote from: Humbugger on September 04, 2007, 03:41:43 AM
Well, Ashtweth,
I believe it is a total waste of time and effort to teach false beliefs and to build known non-working devices.  If we train the youth to believe that the answer to the energy problems is to be found in Bessler wheels and magical non-existent "free energy" devices, they will fail to solve the real problems in real ways that provide real energy for real tasks.
I have yet to see any evidence that convinces me otherwise, whether from my own tens of thousands of hours of bench work or from the emerging verified work of others.  Writing up lies and finding clever ways to yield false test results to make them appear true has been done to death.  It's not the answer.
I'm sorry that my beliefs and the fact that I express them bother you so much.  I suppose you can probably use your power to influence Stefan to ban me from the forum.  That would certainly show the world something, wouldn't it!
Humbugger
No Hum, i would moderate you not ban you, some of the stuff you say is useful, most of it is utter CRAP.
You haven't built and verified any thing so i feel you talking to your self Hum.
I still think your attitude sucks, and i have had to edit and waste a good deal of time here proving this to you. dont expect a direct answer from me in the future, as you have already pissed me off and made me waste time i could be editing the video for the board.
Gentle men , the video wont be ready till prob 2 days now, you can thank Hum for his objective scientific approach, and trying to accuse a non profit org of not helping the whole situation.
there you Go Hum, maybe now you can think about your attitude.
Humbugger
"Its a shame we have so much crap to sort through thanks to Hum."
Good night Ashtweth.  I am sorry you feel that way.  I will not post further on this Charles Campbell matter.  You are free once again to weave your tall tales of amazing machines without further burden of critical comment from me.  I give up.
Good luck to you in making good your promises to the children.  You will live in the world which you create.  Go for what you believe in!
Humbugger
GraViTaR
Quote from: wattsup on September 04, 2007, 01:37:11 AM
@GraViTaR
All that's happening is A and D are turning B and C. But how?
It's a gravity-torque feedback system. The ratios must be exact or it won't work. If it's off just a little, the system will lock up and not run.
The weight of D resting on the inside of A at an off center (approximately 3:30) position, turns A clockwise. The outer surface of A turns B/C counterclockwise by contacting B. C turns D clockwise again which then turns A and the system just feeds back on itself to keep turning.
The contacting surfaces should be alternating metal/rubber/metal/rubber. So A would be solid metal, inside and out. The rim of B would be rubber; the rim of C, metal; and finally, the outer surface of D would be rubber. The slight give in the rubber would give us a small margin for error in the tolerances of the ratios.
A is wide and is a split wheel. It rests on B just enough to make firm contact. B is on both sides of C and contacts both halves of the split A. C is narrow and contacts D through the split down the middle of A. D is a ring that sits freely within A and is not connected to anything. It is wide enough to rest on both halves of the split A at 3:30 and C at 8:00.
Joh70
@Ash: hi ash, don't care about Hum. Relax and do your work. Thanks.
@Hum: "I believe it is a total waste of time and effort"  WHY THEN do you post the most stuff here??? i realy do not understand that!!! Thank you for "giving up" spamming.
