Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
Joh70
This sknooker wheel will never work, beleave it. DON'T TRUST UNFINISHED DEMO-UNITS.
@Zero: Each energy-gain out of bumping against something needs more speed which needs more hight at starting position which has to be charged first.
@Stefan: If you have a wheel with 1000 Balls and you have a proper configuration and enough space for the balls to rest on the levels, you can let the wheel turn a long time until the upper level runs out of balls or the lower level gets into a jam.
In case of having fixed and same degrees on the inner and outer circle for the balls and/or multiple revolutions, it will even don't do that. It will come to a rest short before the first ball is back up again, because of the friction and losses. In best case you have a system converting kinetic energy stored in balls on the upper level into rotation until it is balanced out. It will not gain additional energy. You will soon have problems to lift up enough balls back again.
Maybe your torque calculations are correct (i don't read them). But only when you have no losses. In practice you have losses, it comes back up again max. 99% and then rests, even when balls still available above. And it often will not do that, because the torque is not always the same, because the balls fall in and out (pulsating), and torque is only max. at 90? to the axle - factor is sin(angle).
In other words: Additional torque on the way down falls together with shorter lift = same work. Indeed one ball on the left has more torque than one ball on the right. But it should turn x-times longer, to lift up the right ball completely. The right ball on the inner circle draws x-times the angle of the covered portion of the outer circle, where the additional torque occurs. So all "overunity" is compensated by ratio. Its nothing else than a gear-box. The gear-ratio are the diameters-ratio.
Game Over.
rMuD
1 week from today, there will be a few people there, manually load the device, and prevent it from dropping balls...  and it will be confirmed..  I have no doubt with the basic math of newton's 2nd law equation that it will be in equalibrium..  we spoke of pennies on a cardboard disc, we've shown in pictures...  as much as we can wish this to work...  there is no zero point, there is no "impact" energy gained.. it's all basic 5th grade newtonian math going on here..  there is no force, extraction, or anything that hasn't been tried for the past 3000 years with this, nothing is different..
THE ONLY WAY THIS DEVICE WILL MOVE IS IF A BALL FALLS OFF THE TRACK ON THE UP SWING, 2X 3X 4X 1000X
ps: will the "MIB" and/or The Oil Companies please send me my T-Shirt and my badge
ashtweth_nihilisti
Chas states you cant load this wheel, he has an engineer going over there to fix the wobbling in a few days, and he is going to attach just a magnet and position a copper coil if he gets it working.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Humbugger
Quote from: rMuD on September 08, 2007, 03:14:50 AM
Your order is being processed as I write.  For cover purposes, I must pretend momentarily that I do not have you fully imaged and tracked at all times...therefore, for public consumption, WE NEED TO KNOW WHAT SIZE YOU WEAR.  Oh...about the badge...
Badges?  We don got no badges.  You got badges?   We got no badges.  We don need no stinkin badges!
GEE ~ BALLS FALLING OFF?  SEEMS I SAW A LOT OF THAT ON A CERTAIN VIDEO SOMEWHERE ~
rMuD
Quote from: ashtweth_nihilisti on September 08, 2007, 03:20:31 AM
change the gravity on the upswing, you got a chance.. I hope for the best..  if it's half working please use human effort to simulate the gates, as that can be solved, as long as it doesn't involve lifting balls, or putting force down...
