Thanks to ALL for your help!!
The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
brnbrade
Doug56
Hi Stefan,
Sorry, I don't have a analog voltmeter nor osciloscope.
I will build a bridge graetz in this weekend.
Below I sent a screenshot from software "Spectran" which analises frequencies and show as spectrum. This refer to the music which I have tested in my device. The marked part is where the voltage seems more strong. If you want, I can send the wav from this part to you.
The input signal is from integrated ampifier and speakers that's connected in soundcard.
I connected left and right channel together in a input point, and connected the ground in another input point. I dont know how many watts, but I think that it has 100 - 150 watts. It have small size.
My soundboard is onboard (C-Media AC97 Audio Device).
A interessant thing: When I stop the music, the volts scale jump to negative values (-2,5 / -2 / -1.5 ...) and stay for several seconds arround -1 v. Why?
I need find a harmonic frequency to excite the device ressonance. I will test with another musics and frequencies to see.
@wattsup
Quoteyou have to measure the voltage coming from the sound first
Sure. Zero volts!
QuoteAlso your wiring is not like my current builds but you can try the start-up method and see what happens.
I will try in this weekend in the way that you make.
I also notice that you and some others builders don't followed the Brnbrade's coils orientation, like is shown in pictures (See trial #1). The wiring is inverted. The front set coil is clockwised and the other is anticlockwised. In my arrange, I oriented the secondary in same orientation that the primary.
Regards,
Doug
z_p_e
wattsup wrote:
QuoteCook patent mentions that a wire core will give more tension. meaning current or amperage, hence less potential or voltage. More windings means more potential.
wattsup, actually, the term "tension" is not used very much any more, but refers to the more modern term "voltage".
If you read through the Cook patent, he too means "voltage" when he says "tension".
So for one example, when Cook says:
Quote...to raise the tension of the terminal current...
in modern terms this would read:
Quote...to increase the terminal voltage...
Cheers.
Darren
Bruce_TPU
@ Wattsup
I have two links on page 1 for you.  One is your coil build details and the second it the new way you connected the coils.
@ Doug
Could you please explain how you are placing the sound into your coil?  If buy a speaker, or directly wired?  If directly wired there has to be some voltage.  I have done many experiments from sound card outputs and radio outputs for HHO experiment in days gone by and there is always some small voltage or a speaker would not function.  So if it is wired, please tell exactly how, and how you measured the voltage.
Many Thanks!  :)
Bruce
wattsup
@Doug56
Look at Trial #1 again more closely, you will see that they are wound the same.
This is why I asked Brnbrade to answer those questions so we could have it on record once and for all. But I guess once there are many builds, we'll have time to test other arrangements.
Measure the voltage from your sound with the AC.
