0 Members and 55 Guests are viewing this topic.
chrisC
Quote from: Top Gun on May 16, 2008, 04:26:08 AM
Dear Kul_ash,
The whole analysis is based on the tension (force) in the string having vertical and horizontal component.  The string also has displacement in the vertical and horizontal direction.  We can then analyze the vertical work and the horizontal work.  The vertical component of tension is in same direction as displacement (upwards).  The string thus does positive vertical work.  The horizontal component of tension is in opposite direction to displacement.  Thus the string does negative horizontal work.  This is ?O level Physics? and cannot be wrong.
Since the string itself cannot provide energy, the energy comes from Gravity.  Any Lee-Tseung Pull (including horizontal) that maintains tension on the string will Lead Out Gravitational Energy.
The analysis is never based on perfect horizontal force.  Please do not fall into that trap and mislead yourself and others.
Old Tseung:
Time to take some medication! You're looping again!
Your analysis is based on your flawed understanding of 'O' level Physics.Did you learnt anything at grade school?
Hard to imagine you did. Maybe you were sleeping in class all along?
cheers
Kul_ash
Quote from: Top Gun on May 15, 2008, 06:24:11 PM
Dear Hans,
You have identified the way to change a horizontal force to a vertical force so that it could do vertical work.  The requirement is a "machine".
In the case of a simple pendulum under a Lee-Tseung Pull, we see no "machine".  Furthermore, with such a machine, the output energy would be equal to the input energy + loss.
Thus we have to look at all other possibilities as top physicists.  The other obvious possibility is that the tension of the string does work.  That physics and mathematics is understandable by the average "O Level Physics" student.  Since a string by itself cannot supply energy, Gravity must be responsible in supplying this energy via the string.  This is the Lead Out Energy.
Lee-Tseung obviously possess more than "O Level Physics" Knowledge.  They are the first ones to state the obvious and put that into their patent applications.  They cannot be wrong.
What embarrasses the so call scientific authorities or establishments are - two retirees not belonging to an Establishment pointed out this fact.  The consequence of the Lee-Tseung Lead Out Theory is solving the Energy Crisis by at least 300 known OU inventions.  The Patent Offices and many scientists (and also many paid debunkers) wrongly rejected such inventions for centuries.
When pendulum is in vertical position, tension in string = mg i.e weight of pendulum. If pendulum is moved up by height H, tension in string will hjave a component to balance mgh and a horizontal component which will be pulling the bob to its original position. Result is increased tenstion in string.
The point to consider here is who lifted that bob to give it a height of h. Gravity won't do it. Somebody has to do that work and in normal cases, external force does the job. So you increased mg to mgh and thus equal and opposite tension is induced in the string to balance the system.
Increased tension in string thus is the result of your external applied force and not the gravity.
Quote from: top_gun"They are the first ones to state the obvious and put that into their patent applications.  They cannot be wrong."
They are actually missing the obvious part and thats why their patent applications are rejected and thats why they are wrong.
QuoteThe consequence of the Lee-Tseung Lead Out Theory is solving the Energy Crisis by at least 300 known OU inventions.  The Patent Offices and many scientists (and also many paid debunkers) wrongly rejected such inventions for centuries.
When are you going to accept the fact that none of these 300 so called OU machines are really working? Even till today Milkovic is also completely unable to show a self powering 2 stage oscillator. You seem to be totally dependant on them. If none of these machines ever work, will you accept that your theory is wrong?
ltseung888
Dear Top Gun,
Thank you for taking up the technical questions.
I can now focus on convincing the "powerful" in both China and USA that maintaining Lead Out Energy and the Flying Saucer as top military secret is not worth it.  The World will benefit much more when we can apply such technology.
hansvonlieven
G'day all,
I wonder what happened to Noodledick. Does Anyone know?
Hans von Lieven
chrisC
Quote from: ltseung888 on May 16, 2008, 04:40:06 AM
Dear Top Gun,
Cut the crap old Tseung. Who is going to listen to someone with little understanding of 'O' level Physics?
You need first to be a man enough to admit your mistakes, then perhaps your children will have some respect for you. As for the rest of the people on this forum, you're just a clown!
cheers
chrisC
