hydroxy powered motor
Started by Motorcoach1, July 21, 2007, 05:55:58 PM
Motorcoach1
 welcome I have spent years playing around with this engine. It runs on Hydroxy ( Hydrogen-oxygen)Ã,  made by an electrolysis process that many people have been working on and I felt it was time to introduce this engine to the forum.Ã,  I'm giving this to everyone so it can be builtÃ,  and everyone can make a little profit for them selfs as they see fit, I'm not looking for any monetary gain- I'll build my own units. I'll start out with the major parts and we can refine as needed. one thing will have to be dealt with is the ignition system I have plans on and will present a copy and see how it go's. Any Questions feel free to askÃ,  I'll post photosÃ,  of parts and give the reference to what it is and it's function , I suggest every one that wants to do this, down load the page I'm sure someone that has adobe will be able to put this in PDF format as a user manual. I have chatted with some other folks about this thread and are willing to help out with the cad work and machining CAd file that will be needed. OK here WE go!!!!! july -21- 2007
Motorcoach1
  This is the first part on the engine , The cylinders - There are 6 cylinders on each end on the Motor , heres a model in the photo . the ends are 1/2 inch Aluminum Plate machined for the cylinder insert and the Valving system , the vavle will be coved in another reply. the cylinders are about 2 inches in diameter and have a 1 inch stroke . These are from weed eaters so the size you use will very, the prices i have gotten for the pistons were fairly cheep.
Motorcoach1
 this reply will deal with the rotor cam.Ã,  The cam is 6 inches in Diameter and 2 inches thick with a serpentine cam wave machined in to its faces, This is where the bearing from the piston connecting rod rides on ( there are 2 pistons on each rod - this is due to opposing firring of the ignition system ) every cylinder is opposite on each end of the motor making a total of 12 cylinders. The first photo is the cam model laying on the cylinders with a small flash lite as the connecting rod to show where the cam relation the the stroke occurs.
Motorcoach1
 This is the drive shaft and end caps that will be the exhaustÃ,  to drive the small turbos (one for each end of the motor) this is a 56c frame but I'm going to a larger frame an 86c frame this will allow for the valves to be machined and have plenty of room for exhaust and valves. Theses are striped out Electric motors and just a few parts from the frame are used end caps and shaft (with armature pressed off ) and new bearings , these bearings are real beefy and not to expensive about 4 to 8 dollars each. The end caps have to be gotten off 2 motors you need the C end this is flat and has plenty of room inside. This will be bolted to the 1/2 aluminum plates the the cylinders and valves are machined in. I hope Joe dirt can get us a rendering of the cut away view of the motor so everyone can see how the parts fit together soon. ;DÃ,        These Motor can be gotten from electric motor rebuilders , generaly they would give them to you or sell them as salvage , just explane what you are useing them for and a lot of time the rebuilder will work with you and give you a hand in takeing it apart.  you want to get the 86c frame motor and c end caps
Motorcoach1
 Part 4 . this is where I explain the graph and cam to function of the motor. the first photo is the cam laid out flat and the second one is the one lobe on the cam, we'll start at the high point from the left. as the cam turns on the shaft driving the pistons back and forth the power stroke occurs here and the cam is turned to the piston goes the bottom ( while this one is at TBC total bottom center the piston in the other end of the connecting rod is at it's peak to start its power stroke ) now the piston is at the bottom we have the turbo pumping air into the cylinder , now that we have the air coming in here we only have to deal with the exhaust valve on the other end , These I'm working on using magnetic solenoid valves with built in hydrogen injectors built in them ( that drawing will be covered in an other reply.) the valve stays open even though the piston has moved up. for one helping clear on the burnt gases but we don't want to have to much compression at TDC (top dead center) this may preignite the hydroxy and cause the motor to run back wards. OK so now we have a ONE stroke motor , clean torque , extremely efficientÃ, Ã,  Ã,  Ã,   ( heres a Spiceal note about machineing the cam roter )Ã,   The piston rod connecting the 2 pistons together is critical it runs 90 degrees to the cam and the cam gets thinner as the sine gos from top to botton TDC to BDC
