Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
aleks
Quote from: eldarion on April 17, 2008, 11:57:50 PMOK, I'll bite.  Can you provide a diagram from which I or other members here could test this theory?  I'd be happy to just see this "gravity" force in action around a coil...
If hypothesis is correct, you can. The anti-gravity field should emerge for a moment around control coil when it is pulsed. However, checking it can be really hard in such conditions. You'll need a very sensitive measurements, a vacuum chamber, static charge grounding. Then you can try to detect displacement of any dielectric material placed near the control coil - even if the control coil is enclosed in some kind of material. Of course, if the hypothesis is correct. Well, if it is not, I'll just shut up.
aleks
Quote from: giantkiller on April 17, 2008, 11:05:24 PM
Is that a 'Bucket-o-Keely'? Turn that on and do the Schauberger shuffle.
http://www.frank.germano.com/vortexscience.htm
Thanks for the URL. Those guys also like the word 'implosion'. :) I think there is no much difference between implosion and explosion beside the fact explosion requires "boom" that is dangerous by itself. Both should create gravity change. Implosion is used in atomic bombs so it can be also destructive. The fact about gravity change is what is important in TPU, vortices and rotating magnetic fields are secondary in my opinion. For example, polyphase AC motors also have rotating magnetic fields - and good ones - but they do not produce overunity. Of course, there are not so many AC motors working at 300000 RPM, so I may not be correct in assuming AC motors do not work at all.
sparks
@Alecks
      The reaction on the outside of the coil where gk see's his sparks is the gravity field or ambient dc/magnetic field resetting the magnetic dipole moments of the control windings electrons.  That energy is going inbound to the apparatus,  it is the scource of the seeming overunity.  The controlled "radiation" of a voltage spike or spark induced magnetic disruption is the key.  It acts like a chemical catalyst does but on a realitivistic level.  It causes the magnetic dipoles in the electrons encountered to shift.  This upsets the resonance of the electron and photons are released.  The electrons go cold and set up a gradient to the surrounding field.  A spark is a Realitivistic Catalyst for electron mass disintegration, not annihalation, disintegration.   Man has had this technology before.  4 wings make a good spark gap configuration and a gold plated box makes a good conductor field to be catalyzed.  Now did they have a reed switch to turn it on an a magnet?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
aleks
Quote from: sparks on April 18, 2008, 06:53:58 AMA spark is a Realitivistic Catalyst for electron mass disintegration, not annihalation, disintegration.
No need to use word "relativistic". Gravity was known long before any "relativistic" theories. If Newton was an organist he would possibly think about gravity as a soundwave produced by a huge horn. Then he could deduct that as soundwave frequency approaches 0, its length becomes infinite and speed of its propagation becomes both undeterminable and irrelevant at the same time.
