Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 18 Guests are viewing this topic.
sparks
@GK
   Just make sure the whole boat doesn't get caught in a whirlpool of plazma
and vanish with all passengers aboard never to be seen in this pond again. 8)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
So with the ramp up and the oscilations greater than the pulse height. I need to insert control. Once this thing has a firewall then other testng and results can be pursued.
Small little doo-dads to attain. They might be what we are looking for. You never know. Throwing another log on the fire just might cook your marshmallows or better yet, keep you warm.
--giantkiller. The stuff dreams are made of. Been working so far.
MACEDONIA CD
hi @all
i  all time  say  explane   and we  here   mast  be  concertrate  to real
IF WE WHANT  TO GET  POWER   WHIT MAGNET AND WIRE  THERE IS  SOME  REAL THINGS
<<<<< IF  WE HAVE  STRONG ELKTROMAGNET  AND  MOVE  SLOW  TO  PICK UP COIL THERE IS POWER  ,,,BUT  HOW  TO CREATED  STRONG ELKTRMAGNET    ,,, easy\
  put  only  ampers  there in that coil  and  here is strong magnet
PROBLEM  IF WE PUT   MORE AMPERS THERE   YOU CAN BRING MORE POWER   THERE  THAT IS NOT GOOD
but  if  you make this<<LET SAY  0,2 VOILTS  WHIT  10  AMPERS IN THAT COIL  WOW  WHAT OF  STRONG ELKTROMAGNET  WHIIL BE  ;)
AND  RESOLTS IS THIS ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,  0,2v *10amp = 2watt
tes  you have  2watt in enrgy  and you have 10 amps  elktromagnet
AND  STEP  UP NOW  IF THIS ELKTROMAGNET STRONG  YOU MOVE  LETS SAY WHIT  200 HZ   WHAT  WHILL HAPEND IN  THE   PICK UP  COIL
WE ALL KNOW  THE POWER IS DEPEND OF   HOW IS STRONG MAGNET  AND  <<,HOW   IS MOVING  THAT MAGNET  , SPEED
IF WE  INCREASE THE SPEED   AND  MAKE  LOW  ELKTROMAGNET FILD
IF  WE INCREASE  THE  MAGNET FILD   AND WE SLOW THE   SPEED
THE RESOLTS IS THE SAME
CONCLUTIONS OF THAT      I WHILL  MAKE  HIGH  AMPERS ELTROMAGNET  FILD  WHIT LOW INPUT WATT  AND  PUSH LITLE   FAST THEN  50 HZ
loosecannon
i have read that a few people witnessed Ed Leedskalnin singing to his stones.
i wonder what note that was?
LC
giantkiller
Quote from: buzz-ard on May 20, 2008, 04:15:10 PM
@GK - Just playing around the other night, I started with 50 feet of bailing wire and ended up with about 40 turns, 5" OD, 1 1/8" high, about 3/4" thick. I haven't done the math yet, though - yet another preparatory measure to be taken. Let's compare figures and see if we can work out a ratio that might serve as a reference in estimating these things in different builds.
Later tonight I'm going to secure the new core with zip ties, saw it in quarters, apply a film of lacquer/glue stuff for a little rigidity, then leave one zip tie in the middle of each segment and cut off the others. Winding can happen with a core segment completely inside a sleeve for support, then once the copper coils are wound the core segment can be moved and the final assembly should be fairly stable. So my pea brain says.
Shirt cardboard for the sleeve is an excellent suggestion, and I do plan to make it sorta loose but with enough friction to hold it all in place. The curve aspect shouldn't be so bad, as many shirt collar forms are already curved. Guess I need to visit Needless Markup for some project materials...
I found something interesting. I pull the iron bundle right out of the package and it slips right into a 3/4 od - 5/8 id clear vinyl tubing after slicing and opening in the bundle. I can wrap right over the tubing.
But,
That presupposes the 4" inch diam is one of the parameters like your 5" diam.
I have the tubing cut at a quarter of the ring circumference to wind on.
The idea here is to see the mechanical side first. All the materials fell right into place and are incredibly inexpensive, $8.00. So that lends itself to a spreadsheet of parametrical adjustment of the variables that control the behavior.
And then it hit me! The 5khz is the area where the declining magnetic wave in the iron is tunable or pumpable! I am taking off Friday, tomorrow, to pursure this further. The PMH is not built with this frequency band or tuning in mind. Once you wind, your done. We all know this. But I was able to effect the iron mag field with a pulse wave. As sloppy and adhoc throw together this build was it now produces many answers just by flipping object sets around.
Still have to do calculations.
More heterodyning with light waves:
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TJM-47YXV8M-8&_user=10&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=addb2ff77150f50de452e1f94ad32850
--giantkiller.
