Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
acerzw
@jeanna
Since the picture file you posted has small in the title, do you have a higher resolution version you could post?
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
jeanna
Quote from: acerzw on January 26, 2008, 10:25:35 PM
@jeanna
A
Yes, acerzw
This is a jpg, however. If it is a problem I can repost something else.
jeanna
I am going to move these to a new thread (first time :D )
Again, please see:
http://www.overunity.com/index.php/topic,3996.new.html#new
Thank you
jeanna
Bruce_TPU
Getting back to our discussion of the one wire experiment.   ;)
Sitting back, looking anew at one of the SM clues, and thinking about the "two frequencies (signals) separate power sources, traveling together in a wire."  Up to now, we have started to discuss "opposing" signals, which is what I believe SM meant when he talked about "connected in reverse of one another."  But, he also mentions "slightly out of phase" with one another.  Then you have some kicks!  Thaelin saw this, much more than I did, with 250 volt spikes, using only two frequency generators.
SM's Clue, I have highlighted the relevant part, IMHO:
I originally got the idea from electron circuits which use vacuum rectifiers like the 5U4 GB or 5AR4 etc.
The plate has a high voltage potential with lots of useable power available.
You cant get to it or use it for anything without applying a heating voltage to the cathode or what is the cathode potential of the tube.
So, you put in a small voltage of 5 volts AC 60 Hz which heats up the cathode and welcomes the electron stream from the plate.
Or actually the other way around, but not important for this example of my thoughts.
Now the high voltage power goes through the cathode and travels through the coils of the 5 volt transformer along with the 5 volt AC.
If the plate voltage is not rectified then it is AC with a potential 60 Hz frequency.
That combines with the 5 volt 60 Hz in the coil of the htr transformer and generally amounts to nothing. In fact the power of the 5 volt transformer amounts to nothing.
It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another.
Then you can measure all kinds of things going on.
You can generate all kinds of hash and multiple frequencies, and I do mean all kinds.
What I measured during this process was very interesting.
All these frequencies occasionally met at the same time with a much larger kick at the output.
So, when doing the "reverse/opposing of one another" experiment, using IDENTICAL frequency, but one is "slightly out of phase" of the other, look for POWER SPIKES>Kicks
Please take note, that SM give us the frequency of both of the signals in this story.  He says, "...If the plate voltage is not rectified then it is AC with a potential 60 Hz frequency."  (First frequency is 60 Hz from the tube plate, not rectified.)
Then, he says, "That combines with the 5 volt 60 Hz in the coil of the htr transformer..." (Second frequency, identical, in "reverse/opposing", "slightly out of phase".)
Lastly, the point is that the signals are identical, except for some key things.  Different sources (power supply/battery) and they are in "reverse/opposing", and they are "slightly out of phase" of one another.
I now firmly believe (IMHO) that SM drove the collectors as follows.
FIRST Battery As Source 1:
F1 in first collector
F2 in second collector
F3 in third collector
SECOND Battery As Source 2:
F1 in first collector, traveling in the opposite direction, identical signal as above, just slightly out of phase.
F2 in second collector, traveling in the opposite direction, identical signal as above, just slightly out of phase.
F3 in third collector, traveling in the opposite direction, identical signal as above, just slightly out of phase.
*Note:  Can you picture for a moment, how this could begin to "feed itself" and why SM would say, "because the signal source also becomes the feed for the power source and has the natural tendency to run with gain."
I think this is a major, missing part of our testing.   :(  Let's change that.
Cheers,
Bruce
Edit:
I also want to remind all, of another quote by SM of Tesla:
"In that book it is related that Tesla states that you can have all kinds of electrons flowing through a wire traveling in different directions relating only to their potential power source.
He even said that you could have different electron flows through a single wire completely separate from each other.
I tried it and he is right!"
scotty1
Well Well...like the pic.....
Here is some of mine...NOW ON THE NEW TPU IN NATURE THREAD.....but they are not atoms...much bigger...can see them with the eye  :o
I used a $10 buck plastic microscope to see..
There is alot more to see than shown in the pics...The detail is much better with the eye.
I just put my digital camera to the scope eyepiece and took the pics...ameture... ;D
Scotty
Bruce_TPU
@ Scotty, Jeanna and Acer
PLEASE start a new thread for your pictures and discussion.  This thread is for one wire experiments.
@ Scotty
Some of us have only dial up and large photo's only clog the thread for many of us.
Thank you in advance for your understanding!
Cheers,
Bruce
