Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
Bruce_TPU
Hi Hans,
245 Khz and 35.705 Khz.  35.705 is the frequency of the northern lights, if I recall.
Cheers,
Bruce
hansvonlieven
Thanks Bruce,
I have to think about this one for a while, I cannot readily think where this one might fit in the scheme of things.
Hans von Lieven
BEP
@hansvonlieven
Idea only....
7.whatever was his target at one point.
35.705 was a low as he could make it go so he left it there (larger - higher Q coil)
245 was a maximum of the lower Q higher freq coil
We all know what the 7.? is. 245 would be the series resonance of the altitude of the ionoshpere during the day. Since this altitude changes drastically as day changes to night and back the lower end of the range for that coil would be around 160. Lightning burst have a spectral spike at many places but the two largest are at 1.7kHz and 175kHz (on average going by data collected by other hobbyists and whistler signals I have seen.)
So the thing probably needs to be a variable tuning device to cover changes in ionospheric layer altitude. Since the ionosphere is well known to be the location of most charged particles it seems plausible.
If the above is the way our Earth works then it appears to me that SM was trying to copy that function on a smaller scale.
Just my 213 cents worth (U.S. dollar is pretty much worthless right now  ;D
hansvonlieven
You have a valid argument there BEP,
If SM was indeed trying to establish resonance on some harmonic with the Schumann resonance, there would have to be some sort of a sensing and feedback mechanism (not unlike a servo mechanism) to make this possible.
Food for thought, Thank you
Hans von Lieven.
Bruce_TPU
Evening All,
Here are two more experiment ideas surrounding our discussion of "identical signals, separate power sources, opposing one another, slightly out of phase, (245 Khz suggested)
I only have one more experiment to consider at this time, but will post it at a later date.
A friend of mine hopes to do some experiments along these lines this weekend.  Marco has seen it.  Thaelin has seen something odd.  I have seen something odd.  It fits all of the SM clues.
I think it may be the "circuit potential" we have for so long looked for.  But experimentation will tell.  Some of you have the equipment and are well qualified to carry out a few tests.
Some are buying VHF triodes.  An easy oscillator tube circuit would be handy right about now.
Marco saw wires vibrate.  I saw a very strong magnetic field and RF interference at very low current.  Thaelin saw huge kicks using only frequency gens.
If this is not it, we should experiment, once and for all, and clear the air, so we can move on to other ideas.  IMHO   ;)
I think someone will see something.  ;D
Cheers All,
Bruce
