Meyer's WFC concept analysed
Started by Farrah Day, October 31, 2007, 11:41:08 AM
Farrah Day
Meyer?s WFC concept
I will assume that all SM fans and everyone either experimenting with, or seriously interested in the Meyer?s WFC will have available to them a full copy of Meyer?s ?Hydrogen Fracturing Process?.
The full title of this document is:
The Birth of New Technology
WATER FUEL CELL
Technical Brief
HYDROGEN FRACTURING PROCESS
By Stanley A. Meyer
Inventor
Ok, I used to be a severe sceptic with regards to Meyer?s WFC. Not, so much because I simply dismissed his claims to be able to run a car on water, but because all of his documents (the one above particularly) and patents are strewn with inconsistencies, incoherent jibberish and a pitiful grasp on known science and electronics.  Add to this the video of one of his lectures to a small group of people (in his garage I think!), where he fails dismally to shed any new light on his WFC or answer any questions that his documents raise, and it all looks decidedly dodgy.   At one point in his lecture, someone asks him about ?heavy water? content.  A strange question by any account, but it nevertheless visibly throws Stan.  Meyer clearly bluffs his way forward past this ? I doubt if he even knew what heavy water is.  All in all then, old Stan was clearly out of his depth when it came to the science behind the technology and consequently seemed quite happy to make it up as he went along, hoping, I daresay, to blind people with ?science?. Of course this would work well for 90% of the general public and uneducated reporters out for a story, but anyone with the mildest background in science can pick holes out of practically every page.
That said, what if his invention did actually work, but he just didn?t have a clue why or what was actually happening.
Time then to take a closer look at Stan Meyer?s WFC. However, before I go on it would help if everyone reading this were on the same page and not side tracked by the various other WFC designs out there.  So for the purpose of this thread, forget Dingle, Archie Blue, Kanarev, Xogen, Naudin, Carl Cella, etc, etc, and let?s just focus on Meyer.
Before we can effectively analyse Meyer?s circuit designs, we really need to agree on what the it was designed to do.
Now, contrary to the thinking of many, Meyer?s WFC, his ?water capacitor?, could not use tap water. Use tap water and you don?t have a water capacitor, but a big resistor.  The water therefore, can not be tap, rain or river water, but must be deionized water. The stuff you use to top up lead acid car batteries, and hence not quite so plentiful and cheap as you might have thought. In the Uk a litre of deionized water is around a quid ? currently the same price as a litre of petrol.
Before you consider arguing this point, section 1-1 of Stan?s Hydrogen Fracturing Process, (hereafter, HFP), clearly states, quote:
The Dielectric Properties (insulator to the flow of amps) of natural water (dielectric constant being 78.54 @ 25C) between the electrical plates (E1/E2) forms the capacitor (ER).
At this point, I?ll take a breather and wait for some input before I go further.
Regards, Farrah Day
Farrah Day
"It's what you learn after you know it all that counts"
HeairBear
Also ponder the fact that if he did tell the truth in how it truly worked, he would not have been granted his patents. Bedini states this also. If the words Radiant Energy, Free Energy, or the likes, the patent will not be granted. This leaves the inventor no alternative but to craftily describe the circuit with the days standards. If he proves it works to the law of the patent office he gets his patent. I highly recommend reading all of his patents and the ones cited for references at the top of the documents. The tech breif is to scrambled to understand in my opinion but has it's good points.
Did he not know why it worked? I highly doubt that. If we compare his work to other devices such as the MEG, TPU, Bedini motors, Newman motors, Stubblefield, and so on, we can see the likenesses of all these inventions and that they all produce Radiant Energy using an LC circuit design. A Tesla Coil is a great example.
One last bit is what is it that makes it work? He explains it rather well but I am clueless as how to calculate it. The frequency wavelength or part of or multiples of, must fit in the space between the exciter plates. This "sweet spot" accelerates the molecules in motion to bounce back and forth between the plates without leaking a lot of current, regardless of the size and shape of the plates. I believe Bob Boyce uses the same tech as Stan.He uses a slightly different construction style but achieves the same results. High gas output, low power consumption, and no heat generated from the process.
Of course this is just my opinion...
Cheers!
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
Farrah Day
Yes, Ok, right.
You see, this is where it definitely has advantages in being at least a little educated in electronics.
Firstly, "if he did tell the truth about how it worked, he would not have been granted his patents". What does this mean, exactly? Think about it, if the designs are unworkable, then he fooled the patent office. If the designs do work, but he left out vital components in order that his designs would not be copied (by the patent office?), then that leaves anyone able to patent their own design based on Meyers if they introduce the left out components - and to show it working!!  All they have to say is that Meyers design won't work - which it won't - and show their own working.  The patent issue is quite simply bullshit.
Sweet spot and resonance.  Well Stan certainly did talk a lot about resonant frequency. And, unless you actually have any understanding of electronic circuits you probably will just accept, without question, what he says - afterall you have no knowledge of your own in this field to make any judgement.
What, I would like to know is 'what' can resonate in the wfc circuit on page 1-13 of his HFP document?  Not sure? Answer, nothing.
Reading the HFP should ring alarm bells if you have any understanding of electronics whatsoever. Watch the Meyer's lecture video and then decide whether or not he knows what he is talking about... or not.
If the wfc uses deionized water so we have a capacitor, ok. We then have two inductors in series with the capacitor - effectively a series LC (Inductor/capacitor) circuit.  On page 1-2 of HFP, Stan provides numerous formulae to determinine resonant frequency, reactance, etc, of a series LC circuit. All looks very impressive, and indeed the formulas are correct with regards to a resonant LC circuit.  Problem is that all these formulas only apply to a circuit that can resonate. Unfortunately, Meyers circuit can't resonate because he has a blocking diode also in series with the inductors and the water capacitor which prevents this - so all the fancy formulas are pointless.  This is very basic electronics.. I might add.
If the circuit resonated, then the charges on the wfc electrodes would be continually flipping from +ve to -ve.  This can not happen with that diode there.
The other thing is that even if the diode was not there, a series resonant circuit exhibits minimum voltage at resonance and allows maximum current flow - hardly desirable I would have thought. On the other hand, if it was a parallel lc circuit, at resonance (the frequency at which the capacitive reactance matches the inductive reactance), then the voltage across the capacitor would be maximum while the current flow minimum.
The problem here is the more educated you are the less anything makes sense.  If you start to talk about radiant energy, your in 'Joe cell' world. At no point anywhere does Stan talk about zero point or radiant energy - he appears to try to explain everything with science as we know it and known formulas and equations, however illogical and misguided.
As far as I know Bob Boyce only produces very efficient electrolysis from his cells by pulsing. I don't think he uses high voltage - at least he never used to. He apparently can build apparatus that can fuel a car on demand, but nowadays he only plays with hydrogen boosters, after the dreaded 'men in black' came a-calling.  Make of that what you want - I know what I made of it!
Farrah Day
Farrah Day
HeairBear
Yes, normal electrical theory does not apply in these cases and it seems to me from past experience that EE's have the hardest time trying to understand it. And your right, I am totally formally uneducated. It just may be that people like myself do not have the training ingrained in our heads which can be a hindrance in some ways.
Resonance, this seems to be a touchy subject. Out of all the materials I have read and the videos I have watched I have never found any comments or specific details of the entire VIC circuit reaching resonance. But he does several times talk of the resonance inside the cell or "Resonant Cavity". To achieve resonance in the resonant cavity the frequency (pulsed DC) wavelength has to in some way match the space between the exciter plates.
The diode is to stop the CEMF caused by the inductors. As far as I can see it, the one thing those chokes do is push the electrons back during off times to help keep from leaking to the exciter plate. Even better, the EEC gets switched on at this moment consuming a bunch of free electrons. Here is what I don't get. He adds a third choke tapped to the center of the secondary and calls it an "Amp Inhibitor Coil". If you search a little harder he states his chokes have a resistance of 11.6K. If you use copper and go the smallest wire size you can without breaking it, your coil is going to be huge. 1000's of feet of wire. This is why he chose to use stainless steel wire.
If you read his patents in chronological order, you will find in the beginning he did not use a toroid or chokes in his designs. No LC circuits at all. As he progresses he adds these components later for even better efficiency. So now we can throw out resonance and the VIC circuit and start over with what he originally used. Start with this patent, It's one of my favorites and it's what I have been basing my research on. http://www.freepatentsonline.com/4798661.pdf
Here is a video which I find very interesting. It's hard to hear what he is saying but make sure you hear it. http://video.google.com/videoplay?docid=1200633625949325855&q=Stanley+Meyer&total=528&start=10&num=10&so=0&type=search&plindex=7
OK, what if there is resonance in the VIC circuit? That still leaves the fact of the characteristics of a series LC circuit in resonance is opposite of what we want. A recent journal I tripped across from an MIT student researching wireless power for robotics found that the huge resonant coil in his device, had the characteristics of a parallel resonant circuit. I can't re-find the journal at the moment but maybe you can dig it up. Being that said, would that not change how the VIC works? Is it possible the resonance could be isolated to only part of the circuit and not as a whole?
Radiant Energy. Tesla called it RC or Radiant Current. Stubblefield used it to make wireless telephones and proximity detectors by simply putting a coil in the ground and transmitting/receiving with a simple LC circuit. Amazingly, he was just a farmer who liked to read the science journals at his local train depot. Even though all this Radiant Energy mumbo jumbo seems irrelevant to you, educating yourself with whats left out there will greatly improve your understanding of why these circuits look backwards or not making sense in a normal situation. Does this circuit make sense to you? http://peswiki.com/images/0/02/UPDATED_CIRCUIT.JPG
Notice it has no LC circuit? But it will go into resonance at the right "sweet spot/s" of rpm's. Again, here we are dealing with Radiant Energy and the circuit doesn't make sense in a normal situation. Notice it's called an SG? That stands for "School Girl". Even a school girl can make one! Try it. I did, and it's a great way to get your hands dirty and not spend a lot of cash. Well, In the beginning...... Most of the parts can be found at Radio Shack.
Gotta jet... rock on!
Farrah Day
HairBear, you cannot say that, 'normal electrical theory does not apply in these cases', there has to be some grounding from which to start to interpret what is happening. And that can only be from known science - you can't possibly interpret what is happening by simply assuming that unknown science and/or radiant energy is the answer and work backwards from there!
Even radiant energy will have its laws and rules, we simply don't fully understand them yet.  Things won't just work because we want them to or can simply be explained by radiant energy. But as I said previously, Stan does not mention any such energy anyway, but attempts to explain everything from known science.
Right, HairBear, I watched the video link you provided, and, although very poor quality and without the car being scientifically evaluated is probably meaningless, is still quite interesting.  The obvious problem I have with it is, - hope you clocked it - that Stan in the video clearly states that tap, rain river or snow water will do to power his buggy WFC!  WHAT!  There goes the WFC as a capacitor then, and in comes another major inconsistency with his published documents.  Do you start to see the problem for anyone trying to analyse and sensibly evaluate Meyer's claims? Simply put, his principles of operation of his WFC are incredibly inconsistent.
So Ok, at this stage confusion is setting in. Either he uses tap water or pure water - depending on how the wfc works it can only be one or the other.  Now in the video he uses the term 'natural water' to describe his use of everyday tap, rain river water, but in hi HFP document he also uses the term 'natural water' giving the dielectric constant of pure water. I had assumed he'd meant pure or deionized water when he states 'natural water' in his HFP, but maybe he was talking about tap water. If this is the case we can forget about the water capacitor idea altogether.
At this point can you see just how confused and inconsistent he is/was with what he said and wrote?
He was not a man of science or - as the video states - even a graduate. His backgroung in science and his knowledge was very inadequate when it cam to the theory, that is why I believe he was guessing at what was happening, literally making it up as he went.
That said, if the Dune Buggy worked as he claimed then he did indeed make a significant breakthrough.  His patents and circuit designs as they are though, are complete nonsense and will just lead you on a 'wild goose chase!'
Just while I'm thinking about it, you said that the diode is to stop the CEMF caused by the inductors. Yes but it is the very nature of the CEMF that would cause the circuit to resonate. In a simple single circuit as shown, you cant only have one part resonating!  As far as amp inhibiting goes, if you design the circuit correctly your inductors (at the right frequency) will provide current limiting (but not with the blocking diode there).
Your other link just took me to the patent site but I would like to know what you were looking at, so if you can improve on the link that would be good.
Incidentally, Andrija Puharich (I believe preceding Meyer) was apparently using ac electrolysis, and powered a mobile home with plain tap water in the 70's. I saw one of his circuit designs that was identical to Meyer's cct, but without the blocking capacitor!  His write-up is much more worthy of consideration than Meyer's ramblings and mumbo jumbo.  Looking at it I would say thay Meyer was basing his wfc on this Puharich design. If Meyer's WFC worked I'd bet money on it being based on Puharich's work. See: http://www.rexresearch.com/puharich/1puhar.htm
Regards, Farrah Day
Farrah Day
