HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
acerzw
@tink
Mac's device is based on SM's words but is not meant to be a replication of the TPU, just another way to do the same thing.
@Macedonia CD
It would indeed be interesting to hear your ideas on the TPU Mac.
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Earl
Hi MAC
Is it correct all 5 toroids are the same?
Also same number of CU turns for all toroids?
Is it correct that the collector toroid is **NOT** looping inside the 4 exciter toroids?
The collector toroid does not go through any of the 4 toroids, collector goes through none
of the 4 toroids.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
dutchy1966
Quote from: Earl on November 12, 2007, 07:43:03 AM
Hi MAC
of the 4 toroids.
Earl
Hi Earl,
I don't see why the collector would not go through the four control coils? Where do you base your question on? Am I missing something
regards
Robert
innovation_station
hello i beleave mac has created a magnetic vortex form the 4 coils all they do is spinn the collector coil is inside the vortex that is it
90 deg copulping to the collector from controls weather inside or out side the controls  :)
does he induct current in the collector or does he capture the re  with a collector coil and a diode and a cap  ;D
hummm   try it both ways lol!
i will build  today my ver of this style set up   lol
i will use 4 iron cores for my controls i will wire a collector in side
simple
all out now    those that know   just build and show
it now is show and tell  ;)
ist
hears a question that must be answered
what is RE   i think it stands for returning engery lol
MACEDONIA CD
HI
REPLI TO INOVATION
LOOK  IS NOT A HAVE INDUCTIONS ON ATHER SAID OF MY 4 COILS
IS YES ROTATIONS COILS
I SEE DONT ANDERSTAN ME WEEL
SIMPLE MY PESIMIST  <<INOVATIONS >> IS LIKE YOU HAVE SMALL MAG PER.  HO MAKE  A TURNS  AROUND THE ATHER COILS HMMMM
YOU MAKE SIMPLE TEST  AND YOU WHILL SEE  THIS  OK
IF YOU READ SOME OF MAILS FROM SM  AND HI SAID  MAG WHIT  SPEED LIKE  SHOT GUN
WHAT YOU THING IF YOU MOVE THIS SMALL MG WHIT THIS SPEED IN THE SIMPLE WIRE
HAAAA MORE WHATT
IS HAVE ANTHER WAY TO GET MORE PWER  YOU MAKE  TEST THIS
YOU GET  SOME WIRE CU 12 INCH  LENGHT  AND MOVE  MAG  PER.  THIS WIRE PUT IN THE SCOPE IN LOW METRES AND SEE THE THERE
YOU MOVE FIRST LEFT AND RIGHT
  YOU SEE THE SCOPE  IS GOING UP AND DOWN IS OK
  BUT WHAT IS HAPEND IF YOU MAKE MOVING MAG AROUND THIS WIRE  YOU SEE THE SCOPE  YOU SEE MUCH  VOLTAGE   WHIT THE SAME SPEED
THEN YOU SEE  A TEEL  WHAT YOU SEE
ANTHER TIME I SAID TO YOU  WAY YOU ARE MAKE A MYSTAKE  YOU HAVE PUT  MORE ENERGY IN THIS COILS THAT IS WRONG  IF YOU ARE GOOD MATHEM OR ELKTRONICS MAN  YOU FIND THE WAY HOW YOU TO MAKE 4 COIL  TO PRODUCED  MORE  MAG FILD  WHIT VERY SMAL  ELECTRIC CURENT    8) 8) 8)THE POINT  IS THIS
SM WORDS <<< SMALL MAG  WHIT HIGH SPEED THAT IS THE ANSFER>>
SM WORDS <<<1000 PIECS OF WIRE  IS THE SAME OR SERILAL  OR PARALEL   ???  LET SAY PARALEL  1000  LONG 12 INCHLENHT WHIT  SPEED  YOU IMAGEN THIS POWER
I >> I DONT SAY YOU ARE SAY THE INDUCTIONS  OF 4 COILS  THE MOVING FILD   ;) ;) ;)
OHHH MY GOD THE SM  ALL TIME IS SAID THE TRUE
WHIT SOME SECRET WORDS
REPLY FOR THE ANTHER GUY <<TINK>>
FOR HOW IS WORK TPU
I THING  THE SM IS MADE  2  OR 3 DIFERNTS  TPU
THE FIRST TPU  WHIT  ONE MAG IS  HO DONT WORK  UP SAID DOWN  IS LIKE THIS
LET SEE
  THE EARTH IS MOVING  LET SAY  IN THE LEFT SAID  OK  AND HIS FREK OF MOVING IS 7,3 HZ    THE SM SAID HIS DIVICES WORK 7,8 HZ  CLOUSE TO THE  EARTH  HZ
THE POI OF HOW IS START WHIT MAG  IF YOU HAVE 2 COILS  HO WHIL MAKE  ELKTRO MAGNET FILD  JUST A SECOND  AND COILS  IS CUT  IN NOT PARALEL NOT  SERIAL ATHER WAY  << PARALE  LIKE  X >  WHAT WHILL HAPEND  THE ONE COILS  IS MAKE  ELK. MAG FIL  THE ANTHER COIL MAKE ANTHER ELK MAG FILD  BUT THIS COILS IS MPUT IN THE  IRON METAL  AND THEN THE 1 COIL AND 2 COIL IS HIS POLES IS PUT IN THIS WAY  <<LIKE  N POLE TO N POLE  THE ATHER SAID  S POLE TO SPOLE >> THIS EFECTK IS LIKE YOU HAVE TWO MAG  AND YOU CAN PUT IN TOGETHER
AND  TIS EFCT IS  POSIBILYTY TO MAKE SOME OSCILATION S IN THE SAME COILS  THIS SIMPLE PUSH  JUST SECOND  IS  GOOD TO START THE  OSCILATIONS AND WHEN IS OSCIOTAIONS BEGAIN  IN THE SAME COILS IS PRODUCED  THE INDUCTIONS OR SOME VOLTAGE  AND THIS VOLTAGE  IS HAVE ABLE TO PRODUCED AGAIN THE EL. MAG FIL   AND  THIS FILDS   S AND S  ...N AND AN  AGAING SAME PROCES
WAY IS NOT WORK UP SAID DOWN  A SAID TWO FREKFENCY  THE SAME  HZ  IS GO TO 0  OSCILATIONS  THE MOVING OF EARTH  MUST BE THE SAME MOVING OF MAG  OF TPU
ANTHER  THE MATERILASIS VERY IMPORTAT TO THIS TPU
THE COIL 2  MUST BET PUT IN THE SPECIAL MATERIAL  HO HAVE ABLE TO MAKE  AND TRANSFER THE MAG FORCE  SO FAST   TO ATHE MATERIAL  HO IS ABLE TO CHARGE MAG  FILD HO HAVE SEND THE FIRS MATERIAL
  TRANSFER MATERIAL IS  ABLE FAST TO SEND  ELKTRO ,MAG FORCES TO ANTHER  MATERILAL   HO HA ABLE TO KEEP THIS MAG SOME SECOND
TRANSER FAST MATERIAL IS  <<< SOFT  IRON THIS MATERIAL IS SEND MAG FILD  BUT DONT  KEEPT  TO HIM MAG FILD  >> A MATERIL HO KEEP THE MAG FILD  SOME SECOND  IS   IRON SIMPLE .......
THIS IS THE VERY IMPORTANT MATERIALS TO MAKE PROCES   BEAGEN
IF YOU HAVE 2 SAME MATERIAL  THE PROCES  WHILL NOT START  THE SAME MOMENT WHILL END  WHITT NO RESOLTS   IF YOU PUT 2 MATERILAS   ONE HO KEEPS THE MAG FILD  THE ANTHER  HO NOT KEEP THE MG FILD AND EASY TO TRANSFER  FAST  AND EASY CATCH THE MAG FILD THEN THE PROCES WHIL   START TO OSCILATION LIKE PERPETUMOBILE
THE ATHER DIVICES  I MEAN LIKE 10 BULB  AND  800  SM TPU
IS ANTHER
SM IS CREATING  ELTRO MOVING MAG FILD  WHIT HIGH SPEED  LIKE A SAID UP  PIC 16F
I SOON SEND TO SEE  THE  PIC OF MY TPU OR SOME THING ELSE
THANKS FOR READ OF MY
THANKS <<<<<< ROBERT  >>>>>>>  I SEE NOW THE MANS  IS INTERSTED FOR ME OF MY THINGS 8) 8) 8)
