HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
hartiberlin
Quote from: Vortex1 on November 15, 2008, 08:42:03 PM
TinselKoala, you beat me to the post, here it is anyway
Lets see:
7.5 volts x 0.3 amps =2.25 Watts. This is MAC's claimed input power.
Lets use a pulse repetition rate of 1 seconds so we are allowed 2.25 Watts-Seconds of energy per discharge.
So we can have 7.5 Volts X 0.3 Amps X 1 second=2.25 Watt-Seconds
Or we can have 22.5 Volts X 10 Amps X 0.001 seconds=2.25 Watt-Seconds
Or we can have 225 Volts X 100 Amps X 0.0001 second=2.25 Watt-Seconds
The energy released is the same in all 3 cases, 2.25 Watt-Seconds or Joules
Well,
but he said now:
190 Volts and 40 Amps for 0.2 seconds.
So that would be according to the upper calculation:
190 Volts x 40 Amps x 0.2 seconds= 1520 Joules or Wattseconds
Well, I guess the 40 amps is only the peak and will
not last the whole 0.2 seconds and the same goes for the voltage,
so the output energy is still much lower...probably at least a factor 10 to  50 lower..
So Macedonia CD, please let us know, if you really used a halfed meal zinc can
for the output coil and why you don´t post a scope shot on an output resistor
or the schematic ?
Why are you going to play the cat and mouse game here ?
Do you want to play it the same bad way as S.M. ?
tosky
Your energy calculation is base on the condition during 40A at 190V. But it is not true. Assume the screw driver is about 0.1 ohm. If 40A at 190V will immediately exploded the metal not spark. So it may be unload 190V@0A, when loaded 4V@40A. It is easy to measure if connect the output terminals to oscilloscope, observe during sparking.
Current step up device must fail to use 1 turn secondary to get 190V.
Voltage step up to get 190V at unload.
Current step up  to get 40A at load.
There is no circuit can both step up Voltage and Current at the same CONTINUE time. But it is possible to keep energy in high voltage Cap. or coil then release it at pulse time. Only compress time (pulse) will do the step up both Current and Voltage. Otherwise it will be a real O.U. device.
Gobaga
The tungsten element of a bulb does not break from high current - period.
It will break from high frequency or sudden change.
The sparks of the screwdriver are same as all steel sparks - no fancy colors - just orange darts.
If more of you got off your ass and did work, you would see that this is not what is believed by Mac-CD.
Then there is the fact that the "other" current does not manifest in this way.  Tell us that the output changes whether is night or day - then you have the other current.
So, turn off the damn soap opera!
nightlife
 I think you all are for getting what Tesla has said about how a higher voltage is created by pulsing a coil with a lower voltage and then slam that coils high potential in to the low potential of a second coil and the point of contact is where the higher voltage spike is created which can be redirected to another coil to get usable amperage. I think this is what has been done here and I would almost bet that he has two coils and a pulse circuit hidden.
Mannix
Quote from: MACEDONIA  CD on November 15, 2008, 07:59:54 PM
@ MANNIX
THAKS  FOR COME HERE IN MY THEAT.. I  HAVE  LIKE TO  ASK YOU SOMETHING
we know all here that you  have know somehow the mystery man <Steven Mark>.
and you have now some very good secrets stuff of s.m
i m glade that you came  hereand say to me some things
but
my devices i thing  that is have the clouse  some things like you friend s.m
he told youthat his tpu is imgen like 1000 wire long aor paralel and small magnet whit greated sped moving acrouse this wire
and has some vibrations
my device is has that strnge small vibrtans
and has the same efeffckt like s.m put permanenet magnet clouse tpu and aget has no effeckt to this
AND MY DEVICE HAS NO EFECKT TO MAGNET PERMANET AND HAS THE SAME VIBRATION
IF YOU KNOW  SOME ANSFER  I LIKE TO ASK YOU
I HAVE SEE THAT THE S.M TPU IS GETHING MAKE HOT  ABOUT 30 MINUTES
IS THAT TRUE ???
IF MY DEVICES IS CLOUSE LIKE S.M WAY MY DEVICE IS  NOT HAVE THE SAME HOT AS LIKE S.M
I HAVE SMALL VIBRTAION AND I HAVE NO EFFECKT OF PERMANNET MAGNETS BUT MY DEVICES IS NOT HOT
IF YOU HAVE SOMETHING YOU HAVE KNOW OF THIS KIND PLEASE EXPLANE IF YOU WHANT
AND ATHER DID YUO BEALEAVET  IS THE REAL DC VOLTAGE OF S.M TPU
OR IS SOME LIKE DC VOLTAGE ???
                     I LIKE TO HEAR SOME REPLY IF YOU HAVE ABLE TO ASK YOU FRIEND WHAT HE THING ABOUT THIS
THANKS
I have sent you a PM,
unless everybody can do your experiment why post it?
Lindsay
