HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
innovation_station
Quote from: braden on November 19, 2008, 03:08:54 PM
I know many of  you guys have gone round and round in circles tying to fathom this, but for those who still have an open mind ,I ask you to consider this information. I have talked at length over this TPU business with the physicist, whose paper I have  included here . Please read in to the workings of Dr Aspdens work ,then relate that to the COOK patent. What you may have here are two concentric toroids working in parallel that help drive the aether  through exerting a potential across the coils. Please Read and then comment
patent GB 2390941
patent119825
well now that is intresting....
heres the pattend.....   well
he's from concord ontatio as well hummm...
http://www.aetherometry.com/Labofex_Plasma_Physics/Archive/CorreasUSPAbstracts.html#anchor197565
well
ist
lost for words ....
Spider
I think MCD will mostly be remembered for his colorfull use of the CAPS LOCK Key  ;D
THE SMART MEN HAVE LEFT THE BUILDING... 8)
SpiDer
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
braden
Harold Aspden is a physicist from the Uk and the patent is a uk only patent
HEYDUDE
QuoteYes, that could be the right combination.  In old TV sets, is the electrostatic field and the magnetic field from the yokes perpendicular to each other?
Yes, the electrostatic charge gradient is cone shaped and extends from the shadow mask of the pic tube (+) to the neck (-). The yoke magnetic fields act at right angles to the electron beam, and also the gradient.
Present day CRT based TV's work the same way.
QuoteWas not the flyback transformer preceded by a multiple transformer configuration?
There was usually a large mains transformer that supplied many voltages to various parts of the sets including filaments of the tubes. The flyback circuit, besides supplying the high voltage was part of the horizontal sweep that fed the horizontal control windings on the yoke.
Correction to my earlier post about the imploding TV. Vertical frequency used to be 60 Hz, but was changed to 59.94 Hz when color was introduced.
HD
sparks
  @Gobaga
    All Crt's have a problem with imperfect evacuation.  They utilize ion traps.  They also use a trick wherby they bend the beams so that they can get a wider screen out of a shorter tube.  Now if this signal bends the beam too much it gets to the ion trap and sets them flying.  What could be constructed from that is a cone with the ions trapped in the interior of the cone and a high velocity electron field surrounding them.  I had two little ones of these going one day out of the ends of a rusted iron wire.  The ion field loses all atomic brownian motion as it creates a magnetically dictated lattice of neuclei.  Meanwhile the electrons are getting wisked away into the anode.  The positive electrostatic field from the plasma core is very disruptive to air molecules and ionization progresses outside the cone of the plasma.
     This is real powerful stuff and will only happen when you have ionizing radiation wavelengths in play. There is a bunch of xrays and ultraviolet light coming out of these benign looking cones.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
