What is Electricty What is Magnetics?
Started by innovation_station, November 05, 2007, 11:48:47 AM
nightlife
I have found that electricity is nothing more then a frequency. The more vibrant the frequency is, the more powerful the current. The sun would be a good example due to it's enormous explosions accruing all the time. The frequency's created from those explosions are what gives us light and heat. The frequencies are attracted to iron because iron has a resistance to frequencies. This is what gives us light and heat. Our air is made up of evaporated water which contains iron. The iron heats up from the resistance and glows which gives us light as well as heat. The iron content in the air is transparent to the naked eye as is it's content in water.
This is my opinion of what electricity is and it would be the same as saying electricity is a flow of resistance.
Schpankme
Quote from: nightlife on January 14, 2008, 12:32:16 AMOur air is made up of evaporated water which contains iron. The iron heats up from the resistance and glows which gives us light as well as heat. The iron content in the air is transparent to the naked eye as is it's content in water.
nightlife,
I'm at loss as to where IRON can be found in WATER portion of AIR.  Please explain your comment.
Earth's atmosphere (AIR) contains 78% nitrogen, 20.95% oxygen, 0.93% argon, 0.038% carbon dioxide, trace amounts of other gases, and 1% water vapor.
Water vapor can be produced from the evaporation of liquid water or from the sublimation of ice.
- Schpankme
nightlife
Schpankme, when to much water is accumulated in the air it creates rain and rain water contains iron, so there for, the water content in the air must also contain iron. IMO
sparks
     Electricity is just a change in matter as is all energy.  Matter is a fleeting equilibrium between two forces everpresent in the universe  One that wants everything dispersed and one that wants everything concentrated.  Magnetism arises from the dispersion force and gravity arises from the concentration force. Gravity and Magnetism are not the forces they are what the forces do.  All energy is a change in matter.  Magnetism is something the dispersion force does in it's attempt to make all void.  Gravity or electrical potential is what the concentrating force does to attempt to make all as one.
     Iron exists because it changes it's atomic structure according to how dispersion force enacted upon it.  So it has magnetic memory.  It will react to dispersion force in a predictable way because of this memory.  That is why iron is all that is left once a black hole has sucked up everything else.  It can ride on the river of dispersion where a whole sun's worth of matter is migrating towards the center of a black hole.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Schpankme
Quote from: sparks on January 14, 2008, 09:14:11 PMIron exists because ... That is why iron is all that is left once a black hole has sucked up everything else.  It can ride on the river of dispersion where a whole sun's worth of matter is migrating towards the center of a black hole.
Sparks,
There is not NOW, nor has there ever been a BLACK HOLE (not found, not observed); and you acting like a PARROT and repeating the same bs does not make it so!
Big Bang is dead.
- Schpankme
