Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
wattsup
@btentzer and @duff
Yesterday I went and got a torroid transformer input 110VAC -  two ouputs 8.2 and 12vac. Anyways I took it apart to get the ferrite core.  I managed to salvage the secondary winds, but the primary was really a mess to take off.
It is about 2.75'" OD by 1.75" ID and .5" thick.
I will wind this tonight to do some tests.
I hope this new ferrite has a better uH then what I have now. I think Duff mentioned there are ferrites with upto 480 uH and his was around 150 something. My current ferrite should then be a 2. lol
What would you say would be a good winding strategy? If the second coil wound over the first or in between. I see btentzers' trigger is not going over the first two windings, while EMs trigger coil is wound over the coils.
I agree this is not OU also, but it is a good point to start from. I will eventually try my Cook coils on this on the supply side, maybe even one on each side since I have three of them lying around.
duff
Quote from: wattsup on November 21, 2007, 11:37:38 AM
@btentzer and @duff
Wattsup,
I can tell you what I did but of course there are many ways it can be done.
I started winding 10 turns of the collector first.
Then included the recapture winding along with the collector for the next 20 turns (bifilar).
I ended winding the last 10 turns of the collector by itself.
I then went back and wound 8 turns of the trigger winding interspersed between the other collector/recapture at the center of those windings. That way your not winding on top of the other windings and you've layed it down on the toroid.
-Duff
Bruce_TPU
@btentzer and @duff
Wattsup,
I wound bifilar for exactly half the ferrite core, then taped then ends, all very nice.  Then wound the trigger on the middle of the second half.
I too have some ideas to test it with.
Bruce
Thaelin
Hi all:
   Since this is wound on a ferite core, has anyone here used a ferite magnet in its place yet? I have a few from old MW's around here some place and think I might try that. May be polarity sensitive due to the magnet pole. Guess we'll see.
thaelin
Bruce_TPU
Hi Thaelin,
That sounds like a very good experiment.  I look very forward to hearing the results.  Remember our "same signals, different source"?  I am thinking of building a second circuit and testing that as well.
Bruce
