Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
Hello all,
I hooked up 10 LED's in series, two clear, one red and seven yellow.  Total run time was almost 7 minutes.
Next I replaced the 1.5uf cap with the 2.2uf cap as suggested by EM.  I am testing that with two of my clear, red blinking LED's.  The total run time is 15 minutes, 10 seconds and this is still with my double transistors in parallel, hooked according to EM's schematic.  This is actually three minutes less run time than with the 1.5uf cap, go figure.
@ Stefan,
Next I will test two in parallel as you suggest, and then all ten.
Cheers,
Bruce
Bruce_TPU
@ Stefan
I have completed the first test, using the 2.2uf cap, and the two LED's in parallel.  They ran for 17minutes, 1 second, compared with nearly 18 minutes in series, using the 1.5uf cap.  I am going to retest now, with the 1.5uf cap to replace the 2.2uf cap.  I will post the results here as an EDIT:
Warm regards,
Bruce
EDIT 1:
Okay, I replaced the 2.2uf with the 1.5uf and ran the identical test.  The time finished was 19 minutes, 20 seconds.  (Remember, two diodes in parallel and two transistors in parallel)  A new record for my device with only one 1000uf cap in place.  So my question to you EE guys, "Why didn't the 2.2uf cap give a longer run time, as it should have based on R C constant?   ???
@ All
I bought the second ferrite and have some ideas to put it into the loop.  I won't bore you with the details unless it works, then I will post it.  But that is my next test.  It will take a bit to wind the second toroid the way I have in my mind.
MACEDONIA CD
HEY
MAY YOU TRAED TO PUT  RESITOR IN PARALEL WHIT THE CAP  AND TUNE WHIT  MORE PRICISLY  TO GET MORE TIME TO LIGHT THIS LED  ;)
MACEDONIA CD
HEY
YOU MAKE MORE TURNS IN YOURS EXIT COILS AND YOU PUT LED IN SERIAL WHIT  SOME RESISTOR LIKE  10 OHM  BUT YOU MAKE MORE TURNS IN THE EXIT COIL
MACEDONIA CD
YOU MUST TO CHARGE THE EXIT CAP WHIT MORE VOLTAGE  2 TIMES BIGER THEN YOU START WHIT IN ENERGY
THEN YOU CAN GET MORE TIME   BUT  YOU MUST PUT RESISTOR IN SERIAL WHIT LED TRAED THIS  AND SEE
