Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
0 Members and 31 Guests are viewing this topic.
starcruiser
The coil material would have a bearing on this effect though.
Regards,
Carl
Bruce_TPU
Hello All,
This is my rewound barium ferrite coil core.  Secondary wound in the same direction as Primary, also, more turns.  Also, HV electrical tape separating the primary and secondary, instead of the tissue paper I had been using.  I expect good results with this coil core.   ;D  Cudo's to Dr. Stiffler for proper winding instructions.
Holiday Cheers,
Bruce
Grumpy
        -Frank Edwards
Bruce_TPU
Hello All,
I have added my rewound barium ferrite coil core.  I have one lead of the primary not connected.   ;D The other lead of the primary goes to the positive + side of the 1000uf capacitor.
Both leads of the newly wound secondary goes to the negative side of the 1000uf capacitor.
I then placed another 221 ceramic between the leads of the secondary.
New BEST time:  38 minutes 52 seconds
Total time gained tonight: 1 minute 22 seconds.
Good progress for the night.
Tomorrow night, I will hook EM's version of DR. Shifflers circuit to the oscillator.  It should be interesting.  I also want to experiment with placing a primary in a different place in the circuit.  Tried putting it on the positive side of the 1000uf cap and forgot to use a diode (just realized)  ;) and it did not work (will try a new germanium tomorrow night!).
Holiday Cheers, and good night,
Bruce
4Tesla
Hi all,
I haven't gotten my toroids yet, but found a couple in an old PC PS I had.. going to wrap one tonight and try the original MTPU circuit.  I'll let you know when I get it working.
Edit: I haven't been able to get mine working.  :-[  When I get my other toroids, I'll try again.  Man, winding toroids isn't easy. :)  Since the TPU uses the Earths magnetic field, which isn't very strong, has anyone tried a stronger magnetic field by putting magnets on both sides of the coil?
Edit2: Got it working  :) but short run time - about 4min.
4Tesla
