Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Groundloop
plengo
@btentzer
my amp meter is 1ma total and it is showing .2ma so I think it is .00002ma? Right?
Fausto.
Bruce_TPU
@ Plengo
At that amount, of .00002 ma it would have to run for 525 days.  That does not sound correct!  LOL
Can one of the EE's reading this figure the math please?
How much amperage are you drawing on the 20 LED's?
@ ALL
Okay, I am becoming more convinced that here is something strange happening.  Here is what happened.
At about 8:30 this morning I took off the resistor from the 18 hours it was draining.  I allowed the battery to recover voltage until it reached 7.11 volts.  This occurred after a total of about 8 hours.
So it took just over 8 hours to recover voltage (very little amperage).
After testing with the motor, the voltage dropped back down to about 3 volts.
Placed on the oscillator it has already gone past 7 volts to 7.09 volts showing, after less than one hour.
Also a side note:  I added back to my circuit the smaller cap of 250 uf and the 5 LED's.  It seems with a load, the voltage rises faster, in the other battery I am testing.
Groundloop
Bruce_TPU
Quote from: Groundloop on December 20, 2007, 06:20:10 PM
@Plengo,
No, if the amp meter has a full scale of 1mA then what you read is what you use = 0,2mA.
There is a lot of light going on for such a low current. LOL
Ground.
@ Groundloop
I agree.  That is a lot of LED light for very, very, very low current.
@ Plengo
This does help to explain why the voltage was not dropping on this.  It would have to run for 525 days straight, to run the battery out at the amount of wattage you are using.  This is what, day two or three?  LOL
With such small current being used, one can not say quite yet, based on the volts rising, that the battery is being charged.  My metal hydride battery, goes up super fast in voltage when hooked to the oscillator.  The oscillator speeds that rise time up.  But does it add amperage to the battery?  We need to find some controlled test to determine that.  From what I have seen today in testing, these batteries will never show zero volts, and it is very easy to see the voltage rise, when not hooked to any circuit.  When hooked to an oscillator, the rise time is much, much quicker.  But we need amperage in the battery to convince that it is being truly charged, IMHO.
@ All
I took my drained battery that I then hooked to the oscillator, until it reached 7.13 volts, and hooked it to the motor.  Nothing.  Volts rise up, but no amperage in the battery.
I have decided to let this same battery charge all night and again retest for amperage in the morning.  LED's are to small of a load to test.
NOTE:
On a side note, using Plengo's super efficient circuit to light many LED's, say for a flashlight, that can run 525 days straight would be a great thing in itself.  I would want one for sure!   ;)
If we are to know the battery is being charged and not just tickled, something OTHER than the voltage reading must be the indicator.  Please feel free to post some ideas for tests.  Thank you.
Holiday Cheers,
Bruce
