The Tesla Project
Started by allcanadian, January 22, 2008, 05:56:53 PM
wattsup
@clone477
Are you talking about the rotary switch on the Ozone Patent or are you referring to another patent and if so, which one.
sparks
  Tesla used a motorized spark gap just like the old points set on a car.  You are quite right that once you see the light and corona discharge it's too late.
Plazma formation in the spark gap has to be controlled for as soon as it bridges the gap the current flow from the scource will result in emwave energy conversion directly from the scource.  If the electron cloud stays within the influence of the neucleus an energy void is created between the neucleus and electron field.
It's cold in there and re travels toward this void.  The abrupt cessation of the voltage results in the energy that is heading for this field to smackup against a wall of atomic energy.  This vibration of space results in emwave propogation powered by the ambient instead of the scource.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
clone477
wattsup, Its been in front of our eyes the whole time in these 8 patents
609251
609245
611719
609246
609247
609248
609249
613735
These are all labeled under electric circuit controller.  THIS IS HOW THE CONTROLLER MUST BE BUILT, or we wont see the full benifit of the ozone patent, AND  WE WILL NOT BE ABLE TO ACHIEVE HIGH NUMBER OF MAKE AND BREAK POINTS PER SECOND.
Im aware of the rotary spark gap that is usually used, but I dont think this applies to the ozone patent.  I remember reading an interview and Tesla said a spark gap is a different device than he controllers.  Im alittle dissapointed now because I see that it will not be easy to build the controller the way Tesla says works best.  Im open to some feedback.  Fern
allcanadian
@clone477
It is not the controller that stops the arcing of the contacts, it is the timing at which the contacts open and close. Like pushing a swing at the right time needs little effort, if the the timing is correct there will be no sparks.
armagdn03
F the controller,
blinded you are (to be read in Yoda voice)
This is nutz, i don't even know why I bother posting at all anymore (probably wont), if you read over the posts of the people in the know you will know where to go, who did they read to know what they know? Why do you think ol Erf has dropped of the face of the planet (as far as this place is concerned) because this is wack, nobody makes any progress even tho they were given almost step by step instructions. Even IF someone were to pull this thing off, all you would have is a fancy tesla coil, this was just step one, and nobody has even gotten that far.
Peace out people,
I wish I could turn my brain off sometimes, then I could get some sleep.
