The secret of a working perpetual motion gravity powered device
Started by gurangax, February 28, 2008, 12:33:16 AM
shruggedatlas
Quote from: gurangax on March 02, 2008, 06:41:19 AM
sorry to keep you waiting. I know that you are eager to know how my supposed to work device should work. so without further delay here it is. You may use it for what ever pleasure you want with it. Maybe you already know about this stuff but I found this myself without anyones help.
-regards-
How can it help to merely hold the weight?  You actually have to lift the weight to get it back up to the top in order to insure that the wheel will keep running.  Maybe I am missing something.
hansvonlieven
@ PM,
Habe nicht gesagt was Du da hast ist Mist. Kann ich doch garnicht weil ich nicht weiss was Du machst.
Der Mist ist uns zu erzaehlen Du hast die Loesung gefunden und dann nichts veroeffentlichen, nur damit prahlen.
Das kann Jeder.
Hans von Lieven
@ PM
I never said what you have there is rubbish. I cannot do this since I don't know what you have done.
Where the rubbish comes in is in telling us you have found the solution and not tell us anything about it apart from bragging.
Anyone can do that.
Hans von Lieven
aleks
Quote from: hansvonlieven on March 01, 2008, 09:03:59 PM
Good man aleks,
Keep thinking along those lines. Keely was miles ahead of us as far as acoustics are concerned. Good luck with your research
Thanks. Well, the tube is not necessarily driven by random (heat) movements of atoms. As we know, atoms themselves have orbits where electrons reside and rotate. This can also be considered a random movement since electrons of any two given atoms do not have to be in sync. In that case it must be possible to create some 'microstructure' that resonates to a sum of such movements: it may be an electrostatic resonance (like a membrane in an electrostatic loudspeaker) - also, it's a known fact that diode-based fullwave rectifier with a couple of capacitances can produce a DC voltage from random voltage oscillations - they just need to be greater than ambient heat noise. Then this resonance - after leaving the atom scale - can be fed to ultrasonic resonators and then down to audible range in the same 'reduction gear' fashion I've mentioned already.
Moreover, I've remembered some research I've read about which dealt with "electric-acoustic" bridge and various phenomemons that surround it. Simply put, ultrasonic acoustic waves affect electric behavior of matter and likewise electric fields cause ultrasonic acoustic waves within matter. So, Keely's findings (even if just in the form of rumors) and some of the modern research are in concordance to some degree - so somebody will be able to replicate his device sooner or later. It is indeed interesting because if such 'energy source' possible, it should possible to create matter we need by reversing the function.
gurangax
I know that this is what probably you will think. I did not give the full answer. Look again with 6 arms/6 weights. the arms and weights should be in multiplies of 3. ie 3,6,9,12... etc.
-regards-
gurangax
Quote from: shruggedatlas on March 02, 2008, 11:09:30 AM
-regards-
you miss it. look again, I answered this in the second method. You also need to see how the weight holder is designed.
