The secret of a working perpetual motion gravity powered device
Started by gurangax, February 28, 2008, 12:33:16 AM
helmut
Quote from: gurangax on March 07, 2008, 12:08:25 AM
Greetings perpetual seekers
Just to inform you that I have perfected the design of my wheel. And I can gurantee 95% of the time the wheel will have a one sided torque. It also can rotate clockwise or anticlockwise. But I figured that it won't benefit much by doing that. I'll post the document when I'm finished writing it. Also if you use the second method of my wheel combined with magnetic ramp like SMOT it will produce perpetual motion for sure. But that will be called magnetic assisted gravity wheel. Thanks
-regards-
Charles
p.s My gravity wheel theory won't end here.
Hi Charles
This sounds to good to be thrue
Cant wait to see the plans.
helmut
wattsup
@gurangax
I have been working along the lines you have indicated but there is much more to it then you are saying.
Here is my version 1.0.
http://www.overunity.com/index.php/topic,3070.msg45101.html#msg45101
I will be making my version 2 in the month of April because I have too many projects right now. But in general, material choice, weight size, etc., are things to consider as well as making at least three things happen at the same time to keep the wheel off balance.
The only reason the wheel currently does not turn in my view is the wheel itself is too heavy and the version 2 will be made in 1" thick plastic and the balls will be 1" diameter instead of the 3/4" diameter. This will impart more weight movement to wheel weight ratio that is critical.
Wheel balance itself is prime without the weights.
But to clarify one point you said in your first post of money, you will get no money for this because it will never produce 50 watts, or 1 watt. Such wheels are working on an off balance that is sooooooooo slight that there will never be any torque available to make 50 watts, measured on an actual drag creating load.
I was hoping you had something so incredible (as you were touting it) that even the aliens around the universe would come here to learn, but unfortunately, there is nothing in what you have shown that can qualify in any way to winning the OU prize.
All the best.
gurangax
Greetings all.
You can think what you must think. I know how my design works. I had experience building a non working one before. This I understand. So without further delay. I present you my masterpiece. I've look into your design wattsup, that won't work. that's using 1 axis and get power from the wheel it self. it won't work like that.
-regards-
p.s why limit the post size to 50K??
sorry guys, I'm in a hurry need to go somewhere else. My file is bigger than 50K and can not post it here. I'll send it when I've reduced the file.
gurangax
Quote from: CLaNZeR on March 07, 2008, 01:27:49 PM
Hi Charles
Looking forward to the next Doc and tell you what I will have a go at building it, if the wheel does not have to be too big, looks simple enough.
What size were you thinking?
Cheers
Sean.
Theoretically any size can be built, but you will have to scale it up/down to an to a suitable condition.
-regards-
p.s Well I think it's simple enough for me.
gurangax
Greetings all
Since I can't reduce the file I'll just make 4 zipped files in 4 post. So this would be the first part
