Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
bolt
of course plain old copper speaker wire. There is no iron wire in the tpu. I see exactly how SM  did use bailing wire in the first models and why he managed to get something out of it. Basically as far as the ether was concerned he had an iron core that was spinning. However it wasn't 100% emulation and thus extremely inefficient because he WAS using iron core which killed the emulation may be by as much as 90%. With 10% electrical output 90% would have gone to heat and thats why it only produced 25 watts with dissipation more like 250 watts. After 5 mins it would be as hot as a stove.
I realize there are many magnetic materials and composites. The entire purpose is emulation while the actual device should remain 100% inert. In practice this will never be achieved. Can you imagine the  power of emulation a neodymium magnet?? :)
Earl
Quote from: bolt on March 17, 2008, 07:29:37 PM
[snip]
Basically we are simulating a chunk of iron revolving at high frequencies by emulation that the coil is not a coil at all but we are producing NMR of iron.
Can you see where this is heading if you emulate iron then spin it and wrap wire around it you have a generator!
Yes makes perfect sense! The TPU is replicating a spinning iron atom. We take the pure definition of a iron core spinning in 3D space and reconstruct the effect electrically. The ether then believes we have a bit of iron spinning at high speed and will provide the same effects.
Spinning a piece of virtual iron will have no effect in a coil, unless the iron is magnetized.
I do not yet see that the virtual spinning iron is magnetized.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
Bolt,
how does a spinning magnet induce a DC voltage in a collector coil?
Without a commutator, it should produce either zero voltage or an AC voltage.
Earl
Localjoe
@ All
This Could Be nothing But remember DFRO's post mentioned PHI which is 1.618, 2PHI is 3.236??????????????????????????????????
Now this could just be a weird coincidence but BOLT just posted that IRON a has NMR frequency 3.231 MH    ..... 3.231/2 = 1.6155  pretty close to 1.618 funny thing is what happens if you hit the exact nmr of a substance with an electromagnetic feild ? Does it blow up i dont know but i find it weird also that 1.618 is just far enough from 1.6155 to be considered tuning just off of the main freq as to not hit it.
just wanted to throw that out there
        Joe
As well From DFRO's post
"The magnet on the small device probably just triggered a magnetic switch that turned on the device" ..
sounds like a reed switch to me
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
chrisC
Quote from: Grumpy on March 17, 2008, 06:19:45 PM
What have you done, Chris?  That's right - not a damn thing.  As for achieving OU, I might have been close once, but then so have many others.
Hey, I'm have never said I was winding coils and researching this or that. I actually said some time ago I did not even have a scope! However, that said, from what I have read and understood, I believe in this one or two of Spheric's post, there is much more substance than so many of these "know it all" people...
cheers
chrisC
