Thanks to ALL for your help!!
Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
singerxyz
After listening to Jack Durban talk about SM, I get the feeling that the only switching was 'organic' using reed switches between coils, with the frequency being determined by the coil length. This would make them fire 120 degrees out of phase. And if SM was as unschooled as Jack suggested, we should do as Einstein said - Keep a beginner's mind. To the beginner, the possibilities are endless, to the expert, it's either A,B or C...
Grumpy
I think this is Jack's way of offering his services to anyone who may have a working device - a marketing tactic of sorts and not much more.  He even mentioned that he had heard that a group had a working TPU.
If SM knew nothing of electronics - why all the stuff about specific tubes?
Jack's on a fishing trip cause he could figure out the TPU either.
        -Frank Edwards
singerxyz
Quote from: Grumpy on March 23, 2008, 12:05:45 AM
The tube stuff may have been a ruse, we don't know. But let's not get emotional about SM or Jack. It may be true that Jack is looking to get involved in the marketing (among other things...) and that's good! We need guys like that too. And I know his products are used in the real world as I got very frustrated a few weeks ago in Florida trying to get my shopping cart to my car parked just beyond his electronic barrier ;-) . Also, he readily admitted that he couldn't reproduce the TPU. He may be simply the guy that contact's that one right person who adds the missing piece- he seems to know many people intimately involved with the project. I consider him an asset to the team right now...
BTW I think his comments on the 20 minute meltdown may validate the theory of magneto-restriction as the working principle in the TPU. Something to consider and perhaps plan for.
infringer
may be way off topic but a month or so ago there was a big kick with homopolar generators while this work is far from finsihed I am curious if anyone has ponderd the thought of a homopolar generator inside these rings as it seems that homopolar generator generates a magnetic spin of sorts hell maybe even a homopolar generator inside of a homopolar generator.
Sorry to include just had the dumb thought to share in case of importance though I felt it would do no harm to suggest something to add to possible testing...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
spherics
It appears I have been too brief in my presentation. I truly believed that there would be a group here who would be able to make the leap between the Steven Mark devices you are familiar with and the design that I showed.
Firstly although this has been mooted I am not Jack. All I will say is the interview says more about the character of Jack than it does Steven Mark. I will also add that the SM device uses rotation. I say this without doubt and Jack is wrong in saying rotation is not necessary.
I will now talk about the Steven Mark designs you have seen in the videos and the like so you will understand why my design at the start of this message works.
The SM designs all work on the same set of principles. A pulse into a coil generates an expanding magnetic field. The magnetic field comes into being by an underlying patterning of the ether. It is a cascade action on the part of the ether that causes the EFFECT of an expanding magnetic field. If you then cause a second magnetic field to expand through the same space as the already expanding magnetic field, a specific cascading action, apattern is setup in the ether which is the EQUIVALENT of a magnetic field and has many of the characteristics of a magnetic field. By this I mean it will interact with metals, and cause the EFFECT of a current, IF the field is moving across the metal.  I will refer to this field as a COMP field from now on. But please be clear this COMP field is in addition to the expected magnetic field. This COMP field, a patterning in the ether, is dampened and effectively nulled by magnetic metals. This is why if you are using an iron core in the coils named control coils you will never get a working TPU.
No doubt this may be disconcerting to many who have fond references to baling wire, iron wire and the like. I will now digress onto the circumstance surrounding the initial eureka moment as I understand them. Audiophiles who frequent this watering-hole will no doubt have heard of QUAD ESL electrostatic speakers. An essential design element is the incoming signal is sent into, I believe, 7 or 8 progressive delay elements. These elements delay the signal by microseconds each time.
As part of experiments, associated with what would become his 3D spacial control patents, he was using these delay elements with custom made bifilar wound voice coils (i.e. air coils) and unexpectedly detected an anomolous signal on his spectrum analyser.
Steven Mark created his own delay elements using iron wire after several years of intermittent experimentation. The technique was to carefully wrap a bifilar air-coil using copper wire. The longer the length of copper the better but using identical lengths. The two coils were connected to the SAME pulse waveforms in parallel so that the magnetic field is additive NOT cancelling. The delay element was added in series to only one of the coils that made up the bifilar coil. The delay coil was made from insulated iron wire wound into an air coil. An oscilloscope was connected to both COPPER coils. The setup would be pulsed with a dc offset square wave (i.e. 0 to 20V not -10 to 10V) at the resonant frequency of the bifilar coils. The tuning consisted of cutting the iron wire down in length until an unexpected pulse/signal appeared. This pulse is the kick. I will refer to these tuned bifilar coils as kick coils.
You are privy to the information that the COMP field is nulled by iron. Those who so wish may like to take some time to fully comprehend the frustrations of closely packing the delay and bifilar coils together only to find the unexpected pulse was no longer appearing!!!  This is what SM had to contend. And Jack says SM was not technical. Bunkum!!
From traditional electrical engineering view point the kick coils for a particular quantity of energy now put out the expected magnetic field but also put out the COMP field which has effects like a magnetic field. In a world that excludes the ether, these coils are overunity. If the world took into account the ether, then the coils would not be thought of as overunity.
The magnetic field is now larger than expected. All that needs to be done is to rotate this field in a circle and intercept the field with an output coil. The captured energy is greater than the input energy because of the energy apparently created by the COMP field. If you arrange all N poles of the kicker coils so that they point towards the center and pulse each coil in turn you will get a rotating magnetic field. There are many ways to create a rotating magnetic field. A secondary effect of a rotating field is the entrainment of the COMP field so that the pattern in the ether is partially additive. A big problem was the iron in the delay coils. It was found that a large solenoid fed with a DC current to produce a static magnetic field around all of the kicker coils allowed the kicker coils to be tuned with the iron delay coils in close proximity.
Intercepting only N poles of the kicker coils means you get a DC output along with a smaller induced ripple from pulsing the kicker coils.
Feedback of the output into the input was achieved using toroidal saturable inductor switches. I've copied the picture from other messages of the inductor switches. Refer to the patent for an example to see how these switches are used. Early designs used a small magnet to bias the saturable inductors.
All SM devices had small batteries to power the LC oscillators. The LC oscillators were used as control pulse currents to the saturable inductors. To start the process high voltage capacitors were step charged, this is why the coils took time to start-up! The first few pulses came from these pre-charged capacitors being switched via saturable inductors. Part of the DC output was feedback to keep the capacitors fully charged.
My design shown at the very start of this message thread eliminated the need for an iron delay coil because the pattern is set up in the ether outside of the influence of copper metal of the control coils. It directly allows the COMP field to be generated IN FREE SPACE. By placing the output toroidal coil within this free space the COMP field is intercepted. The complete lack of any magnetic materials within this design is what allows this to happen.
I do believe there are elements of information here that you will not have been aware of before. I trust this is enough to convince at least some of you to reflect and ponder more seriously on this material.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19820016542_1982016542.pdf
