Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
aleks
Quote from: comp-tech on March 21, 2008, 10:52:44 PM
88. Now, electrons can travel only so fast along the surface of the wire because of the magnetic flux.
What if you disable the effect of the flux? My unit operates on these principles. Now the electrons float freely without anything holding them back. Electrons at the speed of light are now a possibility!
89. How much energy can be converted from a stream of electrons traveling
close to the speed of light?
This does not make sense as electrons may travel up to 1/5 of speed of light from published experimentation.
In my opinion, even if electrons travel at speed of light, statistically they will carry no excessive kinetic energy: some will add it some will take it. Only flow of electrons between potentials carries usable energy. All other electron energy is ambient energy that cannot be used as it is evenly distributed in all matter (it's thus non-differentiable or differentiable to 0).
Earl
Freder,
yes, I believe that is what Jason is saying.
In my post
http://www.overunity.com/index.php/topic,4299.msg84456.html#msg84456
I theorize that it is RRE (Rotating Radiant Energy) that is pushing and pulling the electrons around the circumference.  Because there is no load reflected back to the non-primary due to free electron multiplication, the device is OU.
Eventually due to electron avalanche, the device goes into thermal runaway.
In other words, the device is NOT tuned to the magnetic field of the Earth, nor related to Schuman resonance, nor Schman energy receiver, etc.  It is like running a comb through hair.
I could be right, I could be wrong.
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
aleks
Quote from: Jdo300 on March 22, 2008, 05:57:48 AM
Now back to point 19. He explicitly states that it is this "rotating field" that "causes" the electrons to flow in the collector coil.... So therefore, one can obviously assume that without a rotating field, you get NO OUTPUT. Many of us have been pulsing coils in all kinds of different ways, but few people have explicitly tried to produce a rotating magnetic field in the device.... I believe that his point there is an explicit reference to the RMF current drive technique!
After a bit of thought, induction of helix magnetic field created by coil wound around an insulated wire MAY help to take electrons off the matter under reduced gravity force. But this magnetic field should be created automatically when you start pulsing the coil, so there should be nothing added to the whole construction. On the other hand, having a pulse coil AND a coil that induces a constant helix magnetic field can be useful. It just have to be wound in a way so that it minimally interferences with the pulse coil: the ideal variant would be the DNA coiling - one coil carries sawtooth pulses and the other coil sustains a constant magnetic field that may push electrons forward along the insulated collector wire. Repeating: coils should not intersect when being wound on the insulated wire, tight wounding is not suggested as this way constant magnetic field will interfere with pulsing and will reduce the 'kick' effect.
Jdo300
Quote from: Frederic2k1 on March 22, 2008, 08:29:51 AM
Jason,
only for understanding. Do you mean, that we have to "push" the electrones around the circumference by a rotating magnetfield like in a particle accelerator ?
regards
Yes that's the basic idea, though I prefer to say that the electrons are "dragged" through the collector coil by the rotating field. Now there is one other component required to make this work. The rotating field alone will not do the job. Remember we need an E x B interaction, not just B. I will elaborate on this in a future post but for reference, check out the page on the MAGVID device:
http://www.usajohnsons.com/cool_energy_stuff/experiments/magvid.htm
God Bless,
Jason O
Jdo300
Quote from: aleks on March 22, 2008, 08:42:53 AM
This post is interesting. I think that Steven was referring to the idea of canceling the inductance in either the collector or the control windings so that you can generate fast pulses without them being gobbled up by the coils' inductance. At this point, I am led to believe that this applies to the control coils since these would be what we are pulsing to produce the rotating field.
God Bless,
Jason O
