Perpetual Motion Wheel Design (Quite Simple)
Started by Alexioco, March 22, 2008, 10:10:11 PM
Alexioco
Weight A, B, C and D Push down on the right hand side of the wheel lifting weight E and F.
When weight D reaches the release point, the peg will fall to the side of the wheel releasing weight D and causing it to swing, passing through stopper 5 and resting on stopper 6.
As weight F, A, B and C push down, weight E takes the place of where weight F was, and weight D takes the place of where weight E was. This motion then keeps on repeating perpetually.
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
PulsedPower
A nobody else has commented, here goes. There will be no net output from this device, gravity acts in one direction, down so the only motion which matters is that in the up / down direction. Motion of a weight in the up direction requires work to be done on it, motion of a weight in the down direction produces work. In this wheel as with all wheels the weight goes up the same distance as it comes down otherwise it would rise or fall with each rotation of the wheel eventually leaving the wheel perimeter.
I have an idea what you were thinking when designing this, that the weight on the LHS is closer to the axle and therefore doesnt need as much torque to raise it as the corresponding weight on the RHS which is further out from the shaft will produce in falling. While any horizontal motion of the weight is irrelvent to gravity I will explain where the missing torque on the LHS comes from, the spring bends and distorts the normally sinusoidal torque from raising a weight on a rigid arm to a more square and somewhat delayed torque. Whatever shape the torque curve on the LHS is the area under it will correspond to the work done in raising the weight from the bottom of the wheel to the top.
Gravity is a powerful source of energy but it can not be turned off for the return cycle, better off making a hydro electric generator then nature takes care of the return cycle :)
Alexioco
No, it?s nothing like that :P
Have you read the description of how the wheel works?
It keeps 4 weights on the right and two on the left, so it's 4 verses 2, well, that has to move, and in order to keep it moving, the bottom weight swings, read the description just incase you don?t understand its workings...
helmut
@Alexioco
Thats a new idea
Did you make a model of that wheel.?
helmut
