The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Grumpy
Quote from: poynt99 on August 04, 2008, 10:22:55 AM
yes good advice
c'mon, you've got time it seems to make these posts- it takes only a few seconds to post a pic, that is if you've got one. cut the BS and just admit it, you don't.
Pynt99 is correct.
We must have the character (or BALLS if you prefer that term) to get off the soapbox and show by "observable phenomena".  Then when we state "the moon is hollow", no one will utter a word of contradiction.
EDIT:
By no means am I saying that anyone should post stuff that would be detrimental to anyone in any way shape or form.
        -Frank Edwards
sparks
     The spike is powerful in that it creates a very dense energy field.  It doesn't go anywhere where comes to it.   Resistance of a conductor produces heat in proportion to the current flow.  What if the resistance of the conductor was actually causing cold spots and the ambient field heat is  concentrating in the conductor.  Something like how the sun works.  The corona being hotter than the surface.  The surface sucking heat  and the magnetic field containing the input. What frequency does heat have around here.  Infrared I think.  Infrared wavelength into the spark gap dc gain out of the spark gap/tube/pn junction.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
brnbrade
Quote from: poynt99 on August 04, 2008, 10:05:49 AM
could you say a little more about what you mean exactly?
doesn't the flux vary with current? with an AC current, the flux will vary in direction and time.
hia all
If charges dont vary in the time, dont true gains,  .
it only converts voltages, with little or without gains. but it converts, it does not generate nothing. only high voltages with small amp.
Flux is charges or currentes of eletrons, ampere is intensities of charges .
The coils inductors saves the energy in mag-field,
It breaks the producing of the power because saves the energy and produces nothing.
regardes.
brnbrade
Quote from: sparks on August 04, 2008, 11:55:11 AM
Creates a very dense because inductor save the energy in mag field. The heats are the causes of density (histeriase, currie efect…)
