riddle me this HHO man...
Started by Nution, June 16, 2008, 07:12:59 AM
innovation_station
can i ask what is wrong with a boiling pot of water
as i have have seen and read the hotter the better   no??
have a look at cold fusion
http://youtube.com/watch?v=oLUeGX3hNpU
ist
hunter
I have a 9 plate unit, the plates are + - + - + - + -+ It started with 5 amps than after one and a half hour ended up almost 30amps so the ABS pipe canister was about to melt because of the heat, I just used a little sodium hydroxide. Than I did install it in the cabin of my car, and also installed a 30amps pwm dc motor controller, so now I keep the amps under 10 and don?t heat up either. Now I?m going to install the 15 plates unit next to this one I made, and keep both under 10 amps
sigmaX
Hi peeps :)
I just build an HHO generator for my car. I am waiting to buy an amperimeter clamp, so I can be sure of current consumption.
Maybe someone of you can clarify some concepts to me:
There seems to be two "schools" about voltage and current (or maybe I got everything wrong).
1) Not more than 2 volts are usable for hydrolisis. BUT HIGH CURRENT is a must (being the most used configuration the ones that use +||||||- -||||||+).
2) (the one that uses pulsed current) is: LOW current but high voltage (like Meyer's tubes o ravzz pulsed current modulator).
My cell actually is composed of 16 ss plates (15cm x 5cm)  separated by 1mm aprox, in +-+-+-+-+-+-+- configuration. My tester was not a clamp one, and reached up to 10 amps. It gave an error. I took it off, and using my CB radio 12amps power supply, I also burned its fuse. Now I am wondering how many amps my "monster configuration" is eating ...
For the three or so seconds that it worked before burning out the fuse, the HHO production was VERY GOOD.
I used tap water, with no electrolytes added.
Now I am also planning to try distilled water, just to see if I can lower amperage.
If things keep being this out of scale, I will switch into pulsed high voltage, low current feed (with a power inverter, just to see what happens). Then I might try to build the ravzzz pulsed circuit, if things look promising (or keep the power inverter attached to the system).
Anyway; I am also building several measurement and safety sensors to be rigged into the HHO generator, inside my car:
A pressure sensor (that will monitor HHO build up and water level, inside the cell), a temp sensor (just to monitor if things get boiling), a voltage sensor, probably a current sensor (this one is not decided) and the whole contraption is controlled with a 70A automotive relay so my microcontroller can turn it on / off at any time. Just for the sake of it, I will throw in a transmitter, so I can monitor every parameter from the inside of the car without cabling anything.
I am waiting for some parts to arrive. The transmitting and receiving platform is already built.
So, if any of you got any idea or recommendation, I?ll be truly thankful...
Regards,
Enrique
sigmaX
Hi peeps :)
Regards,
Enrique
innovation_station
finally i have been impressed by the nutrel plate cell  ;D
i took 1 of the plates out of the 4 plate cell and loaded the soda to it it is statring to get damm hot and amparage has not exceeded 10 amps yet been 40 min since i fired it up
production it great  not as much as my other cell +-+-+- but it cosumes hot 1/3 of the of the start up of my high amp cell cold lol
if that makes sence
  i am watching the amps closely the time and the temp this is a dirrect connect to a battery
ist
