riddle me this HHO man...
Started by Nution, June 16, 2008, 07:12:59 AM
Mr.Entropy
Quote from: Nution on June 16, 2008, 07:12:59 AM
What is the purpose of a neutral plate?
4 "neutral" plates (they're not actually neutral) turn a 12V cell into 5 2.4V cells wired in series.  Water electrolysis only takes a couple volts, and production in each cell is proportional to current.  Power spent is current*voltage, though, so putting more volts than you need across a single cell wastes power.
innovation_station
just tested the 6 plate 4 nutreal plates  in just tap water resualts were crap  slow production  mind you amps were verry low none the less i much perfer the heat and high amps... this was connected to the 12v deep cycle battery dirrectly as are my other cells
i will stick with the high amps as the cost to make a lower amprage high volume cell it way too much in ss alone plus the container will take too much time to build and seal
i have ran my unit for 1.5 hours nonstop  testing it out and no concerns heat or other wise it gets damm hot yes but the abs 4" sch 40 seams to take it well  this is a dirrect connect to the battery fully charged im useing 4ga car audio power supply wire after 1 hour run production is large
ist
Nution
Do you know what type of amps your getting towards the end of that 1 1/2 hrs? Also the temp of the water? I wonder if eventually it will cap off and stop getting hotter and hotter and just reach a ceiling in temp and amps.. Have you seen that at all? Thanks for the info btw. :)
innovation_station
in what i have seen so far it did not climb much more in temp i did not mesure the amps but b4 i start amps were well over 30 amp draw and that was cold tap water  no electrolite  ;D  but even after 1.5 hours my wires were not hot or melting i have no connections in the can only out put for gas i have wercked a few cans doing it the wrong way in the past
ist
Nution
I am mainly concerned because I am planning a build of my own design that uses a lot of SS electrodes and cathodes. I am worried that the heat might melt the whole thing to the ground lol.
I have some measures in place to improve cooling, I just do not know how effective it will be and I want to make sure I do not pass any thresh hold that is to dangerous as far as amps and heat goes.
I have all the parts and am ready to build it, just want to make sure I put it together right and not just end up making a boiling pot of water.
