URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gmeast
Got my new tranny for VexUs oscillator.
Hi all,
I just got my new tranny from Digi-Key today and changed out the old one. I also eliminated the voltage multiplier for test reasons. It is important for the plasma arc to not decrease in magnitude with increases in frequency ... or more simply engine RPM.
I have included a scope capture showing the engine running at around 4000 RPM. This can be computed from the period between each discharge event. So every 7.5 u-secs a plasma discharge occurs. With 4-cylinders and every other cycle for 4-stroke ... do the math.
The trace is the same for each event at high speed as it is for idle. The new transformer I just bought for the oscillator fully supports the energy draw required to generate the plasma events at high frequency.
As you can see the discharge transient is nearly 180+ VDC solidly and consistently without droop. I'm very satisfied.
The difference the smallest amount of water makes in the arc is astounding! I am going to introduce atomized water in the intake air as a first test. I am in the process of building a SID CELL Hydroxy generator that I will eventually run in the Bug.
Thanks for reading. Peace,
Greg
gmeast
power usage
Hi all,
Now that I am generating ALL of the power my VexUs circuit uses (that includes the oscillator/inverter power) I can give you REAL power usage figures for the VexUs circuit.
at idle: 8A @ 13.8VDC = 110.4 Watts
at 4500 RPM: 10A @ 13.8 VDC = 138 Watts
I just wanted to share this information.
Peace,
Greg
gotoluc
Quote from: GraViTaR on November 05, 2008, 11:36:34 AM
Dude, you cannot be that naive.
Obama is not a great man. He is just a puppet. So is McCain; so is Bush. so is Hillary Clinton and so was Bill Clinton.
Obama is not going to do one thing as president that is of his own design. Zbigniew Brzezinski is the one calling the shots. Everything that Obama does as president will be under the supervision of Brzezinski.
Zbigniew Brzezinski is the front man for The Trilateral Commission. They put Jimmy Carter into office. When Carter thought that he was actually in charge and tried to do things on his own, Brzezinski had the Federal Reserve jack up interest rates to sabotage the economy and make Carter look incompetent.
The Trilateral Commission's ultimate goal is to establish a trilateral, global monetary system via the United States, Europe and Japan. All this is to consolidate and streamline the control that the international private banking families of the Rothschild's already exert over the world.
Not only do they control us through the world's monetary systems, but they also control us through energy. The Rockefellers began as oil barons in the 19th Century and the Rothschilds recognized the tremendous advantages and importance of keeping the world dependent on oil. So they took the Rockefellers into their fold and built up an oil/monetary control infrastructure that exists to this day.
That is why these forums are so important: Because "pay-as-you-go" energy is how they control us, and it is up to us to smash those chains of control and to free the world.
Hi GraViTaR,
thank you for your post as many may not be aware of this information.
I do not wish to talk politics in this topic or in any other topics mind you, as it will not help us in any way. I am aware of what you mention above but I must say that for the first time since JFK I feel this man is special and I have hope once again.
Time will tell.
Luc
gotoluc
Quote from: gmeast on November 05, 2008, 11:50:56 AM
power usage
Hi all,
Peace,
Greg
Hi Greg,
thank you for continuing your excellent development and for sharing with all.
Luc
gotoluc
Quote from: jstadwater on October 30, 2008, 05:24:10 PM
It's just me again,
    I did it this time at 125 psi, 2,300 rpm. The higher the pressure, the bigger the plasma gets!!! Keep in mind, I am ONLY discharging 2.5uF in these vids! The reason, I think, that I had to make a new combustion chamber plate is because my painter was using his DRY air system at the time I wanted to make another video. I used regular shop air and it has moisture in it. The plasma built up size as I increased chamber pressure........And BANG!  I'm betting the large plasma ball ignited the amount of water vapor coming through the air hose, the pressure had no where to go, so it blew out the see-through plate. It was quite a boom, I nearly wet my pants! It seems to me that using an ACTUAL combustion chamber is the only way to get an accurate test result. The shape of the head's combustion chamber is a series of angles and curves........it is that way for a reason! The link is below for the 125 psi test.
VexUs Plasma Vs. 125 psi  http://www.youtube.com/watch?v=DPwYzEZ5gEo
Hi jstadwater,
thank you for doing these important pressure tests and sharing your excellent video's. We now know the Plasma effect is not reduced under pressure as some may have thought.
Excellent work ;)
Luc
