Water for fuel - diesel
Started by nightlife, June 30, 2008, 01:48:44 AM
yaz
nightlife
QuoteNightlife it has been my experience that a diesel will run with no fuel from the injectors  have seen to many runaways  where the motor seems to suck the oil from the crankcase to keep running  [SCARY]  Chet
Hi Chet, you are right. I for got all about that. I was working on a old 1970 Kenworth that had the throttle stuck wide open. The injectors were the problem and if I would have started it, it would have became a "run away" and even if I was to have shut the fuel off, I was told that it would suck up the oil from the pan and keep running until it blew up or ran out of oil. I was then told that some have blown up shops when they did blow.
Therefore, it must not hurt the motor as bad as I thought it would. I was also watching the video I posted and he hosed HHO into his air intake and it seams to run just fine and he is reporting better mileage.
I still think it would be better to inject the water after TDC but do to what you have said and reminded of, I guess I can try adding water to the intake to see if it will restart.
resonanceman
Quote from: yaz on July 03, 2008, 12:45:31 AM
Could these work as test engines??
http://www.youtube.com/watch?v=3g0ri5kiRkM
Yaz
I guess  they could be used for  very short term tests
The  problem  as I see it is that they are designed  to run on oil .   That oil  is not only the  fuel ........it also provides  the lubrication .        Water will provide  SOME  lubrication ......but not  near as much as oil .
Rust could also  be a problem  .
gary
nightlife
I am not good with circuits but I find that s1r has used the coils coil wire for the ground to charge what ever he has in the container. When the coil fires, it breaks the grounds connection.
What can be charged by connecting a negative and positive and then discharged to the closest ground just by breaking the connection?
What ever can do that, must be what he is using.
Tinker
YES
I did a long post to explain it to you and lost it, but you can with some modifications, More later
Be Well
Tinker
