A "RADIANT ENERGY" DETECTOR
Started by Vortex1, August 06, 2008, 08:55:18 PM
innovation_station
well if it can be made with hv it also can be made with low voltage .....  why?
cuz it is the same amount of engery  if you will use hi voltage you will need low amparage ... and if you use low voltage you will need high amparage  8)
right hand left hand  ;D
the return will be the same ...   it has been said as much as 1000 times ...
now if we could only make hv from a low voltage like a 9v battery  charge a cap and dump it to a load fast enough ...  we might have a tpu ...
ist
Vortex1
To attempt to standardize radiant charge detectors:
A quick calculation shows that a 3.58 cm. diameter disc will have 10 square centimeters of  surface area, a nice even number for calculations and it will fit easily into a food type can.
This should provide adequate sensitivity and allow for easy Volts per cm measurement. If I have made an error here it is open to correction.
If we standardize on a one meter (safe) distance of our detector from the generating device, we now have V/cm/m.
I have thought about using a small HV capacitor in the device to filter the output, but this would probably kill the impulse response. A 100 meghohm resistor would provide auto bleed down, but may not be needed as the input impedance of the VTVM  or final measuring device may be adequate to provide bleed down.
Marco says he has already been down this road several years ago. I welcome his posts of test data and construction schematic of his "radiant"  generator and "radiant" detector here.
turbo
What?!
Do you realy think that i am going to write a book or draw schematics??
This has ALL been done before.
You just need to DIVE INTO THE TESLA POOL.
Like i did.
He has written down EXACTLY how to do this and there are more with diffrent methodes.
You really need to read and understand Tesla very carefully and then you will see he slips his tounge here and there.
If i need to write down all i did then i would end up with a copy of Tesla patents and that my friend is a waste of my time.  :)
It is all in his patents.
Marco.
Vortex1
Sorry to have asked, but thanks for the excerpt and the put down. I should be humbly reduced to a newbie.
So Tesla seems to be saying that the generally held belief is:
Extremely high frequency vibrations emitted that ionize the atmosphere through which the waves travel.
Whereas his own belief is that they are charged particles emitted of high velocity, and these charged particles can charge a neutral conductor or discharge a charged conductor in the vicinity.
Seems like the wave/particle paradox again. I will try to research this patent to arrive at the context.
duff
For reference, the excerpt comes from patents: 685,957 & 685,958.
